How To Fix Cold Floor - Air Intrusion From Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 07:18 PM   #1
Learning by Doing
Leah Frances's Avatar
How to fix cold floor - air intrusion from basement
Last winter I insulated the steam pipes in my unfinished basement and so now the basement is much cooler. Cold air intrudes up through our hardwood floors (they're plank floors that have some wide gaps) into the first level causing uncomfortably cold feet (brrr!).
What's my best solution? I've been reading all the posts on the forum about insulating floors and I would love to hear what other people have done to warm up their tootsies.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-12-2009, 08:08 PM   #2
Leah, I just took out carpet with a high quality underpad and laid Pego, right after sealing my pipes and adjusting the basement dampers. The flooring is much cooler under foot.
Now we're shopping for a rug! And I think I'll tweak the dampers back a bit to build some heat underneath again. That and insulate the basement
Chemist1961 is offline   Reply With Quote
Old 01-12-2009, 08:23 PM   #3
What can I find here?
Winchester's Avatar
Rewards Points: 150
Insulate the basement....walls or ceiling, either or. Both are not necessary. Seal the basement where anything exits or enters. Seal and insulate the rim joists if possible.
Best of luck.
Winchester is offline   Reply With Quote
Old 01-12-2009, 11:26 PM   #4
This would be a good option. I have used it before. Just spray it up against the bottom of the floor and call it a day. It seals all air and has an R value Of 6-7 per inch. Drys in 1 min.
http://www.foampower.com/index.php
integlikewhoa is offline   Reply With Quote
Old 01-13-2009, 09:26 AM   #5
Learning by Doing
Can you give me a breakdown of using this product? Was there 'technique' or a learning curve? Are there cons? Does it need to be covered in living space? Do you use the E-84? What about set-up/clean-up?
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
Installing Cold Air Return (Basement) kwtsat HVAC 3 07-22-2008 06:58 PM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 08:42 AM
