How To Fix Bowed Ceiling Joist? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 07:28 AM   #1
Rewards Points: 111
How to fix bowed ceiling joist?
I have 3 bowed ceiling joists that support my 2nd floor. The joist are exposed with no sheetrock, so I want to take advantage and fix now (not to mention the sheetrock will look horrible if not fixed). They are undersized (code minimums) 2x8 that span 12+ft. The sag seems to be only from the crown installed upside down.
What would be the best approach to adding a sister? Thanks for your help
luvdairish is offline   Reply With Quote
Old 11-09-2010, 07:55 AM   #2
Chicago, IL
Michael Thomas's Avatar
You may find this helpful:
Six ways to stiffen a joist – Fine Homebuilding Magazine
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-09-2010, 09:31 AM   #3
Rewards Points: 111
Originally Posted by Michael Thomas View Post
Thank you for your post, but this isn't replacement because of bounce. That is a small factor here. Mainly I want to replace because of the dip above the floor and bow shown in the ceiling below.
Old 11-09-2010, 10:23 AM   #4
Rewards Points: 150
It sounds like you mainly want a flat ceiling but dont care to remove the dip in your 2nd level floor correct. You could find the lowest spot in the ceiling and fur the rest to match with 2x4's 16db nails and liquid nails. But I would think that jacking and sistering on to warped joist would be better because It would also level out the floor up stairs.
STL B. is offline   Reply With Quote
Old 11-09-2010, 10:49 AM   #5
Rewards Points: 111
That's one of the best plans. But how would I take the bow out of the ceiling if the joist is still there? Should I cut the bad joist somehow?
Old 11-09-2010, 03:00 PM   #6
http://www.finehomebuilding.com/PDF/Free/021158084.pdf
1910NE is offline   Reply With Quote
Old 11-09-2010, 05:36 PM   #7
Rewards Points: 150
can you plane the bowed part off?
guest is offline   Reply With Quote
Old 11-09-2010, 10:36 PM   #8
Rewards Points: 150
I may have misunderstood I was thinking that the ceiling was sagging. Is it a sag or an arch like bow
Old 11-10-2010, 07:01 AM   #9
Rewards Points: 111
It's an arch like bow. This occurs in random places throughout the house. The wood was installed crown down. But how to correct that after the fact?
Old 11-10-2010, 07:02 AM   #10
Rewards Points: 111
That sounds like a good idea. I guess I could reinforce with another 2x and then plane the difference.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
partition wall parallel to ceiling joist RedBear Building & Construction 10 03-05-2010 11:37 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
