Old 12-16-2010, 05:57 PM   #1
How to finish closet ceiling in garage space
Long post warning!
Due to a frozen pipe, I was in my mom's garage's attic (abuts her house, shares a common wall). In drawing (just learning google sketch), there is an inside closet that intrudes into the garage. Thick black line is garage ceiling plane. That closet has a heating duct running in it; the ceiling of the closet is drywalled beneath the duct space. In the garage ceiling, the space above the duct space was only "sealed" with faced insulation. I think it should be for fire protection (no way to stop fire from entering duct space from attic space) and to reduce air infiltration (This is what caused frozen pipe: there were 6 of the 2nd floor joist bays open to the garage attic space, one of which had the pipes in them).
So, my question: What should I install from the garage attic space between the joists that lie above this duct chase? I can't install from below unless I rip out the closet ceiling but then I'd have the duct work to contend with.
One limitation: I've about a 2' x 2' ceiling hole to access the garage attic.
Should I cut drywall to fit between the joists (whole space to cover is 36" x 62")? I'm a bit concerned about drywall sagging since I can't install it to the bottom edge of the joists; I thought about running a 1 x 3" flat alongside joists to support drywall edges. Agree?
When done, I'll spray foam gaps where drywall hits joists with fireblock foam and then insulate with fiberglass batts.
Any thoughts?
TIA,
Bob
bob22 is offline   Reply With Quote
Old 12-17-2010, 06:30 AM   #2
My main question: Do I need to have fire-rated covering over this space and if so, what would be best to use? If drywall, what kind/thickness; if I could use plywood or OSB, same question, type/thickness?
TIA,
Bob
Old 12-18-2010, 03:10 AM   #3
starkenwolf's Avatar
5/8" drywall twice....yep 2 layers meets fire code.
starkenwolf is offline   Reply With Quote
The Following User Says Thank You to starkenwolf For This Useful Post:
bob22 (12-19-2010)
Insulation over garage, under master closet PDWalsh HVAC 6 11-30-2010 05:31 PM
Help with garage ceiling joists EKennett Building & Construction 1 04-26-2010 12:22 PM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 02:01 PM
How to fit a closet bend in a 2x8 ceiling cavity benjamincall Plumbing 4 04-24-2009 05:36 PM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 07:58 PM
