#1 |
how to finish beasment walls
hello I like to finish some walls in a beasment . Dint want to build a rame walls was thinking about 2 options walls are from cinder bllock they are dry
1. put on a walls any quickwall cement finish tinset mortal ? and make any faux finish on it . Not sure what to use 2 furring strips ( dont like wood one ) where and how much cost metal one and sheetrack finish ? Thsx for help |
#2 |
I put 1" foam on the walls, tuck tape, and then put a steel stud wall up. 3 5/8" steel studs with 3 1/2" fiberglass insulation made for steel studs, it's a little bit wider. Emt for the electrical. Warm and straight walls with no dust and the studs are lightweight.
#3 |
Moderator
Where is the basement located?
Gary PS. Welcome to the forums!
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Can I run electrical wire BEHIND my basement walls? | GoBengals | Electrical | 8 | 01-18-2012 09:38 PM |
| Putting color onto white brick or textured walls (need color suggestions!) | Eliana | Interior Decorating | 2 | 01-18-2012 08:27 PM |
| Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? | yotaman | Remodeling | 11 | 04-19-2011 10:20 AM |
| how to finish these walls off? | FX4 | Interior Decorating | 13 | 12-07-2009 02:03 PM |
| Cheap Way To Finish Walls?? | bswain06 | General Discussion | 11 | 11-06-2007 03:32 PM |
