How To Find Support Beam On The Second Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 10:15 AM   #1
Rewards Points: 30
How to find support beam on the second floor
I'm going to buy a small safe (about 24"x24"x12") and anchor it in one bedroom's closet. The room is on the second floor. The floor is not concrete. It's tile floor with plywood under.
Sorry if the question is not about home improvement. If it's not appropriated, MOD please delete it.
Thank You
hpdad is offline   Reply With Quote
Old 12-04-2012, 10:28 AM   #2
Rewards Points: 2,212
Are you thinking you need it over a beam/support wall because of the weight?
Or are you asking how to find a floor joist?
Also make sure of it's measurements and that it will fit inside the closet.
mae-ling is offline   Reply With Quote
Old 12-04-2012, 02:47 PM   #3
Rewards Points: 30
Floor joists so I can bolt the safe to. The safe only about 100 lbs. We have walking closet so the size is not a problem.
Old 12-04-2012, 03:06 PM   #4
DIY staff
Rewards Points: 7,174
You want to locate a floor joist or two---
First go to the basement and measure the spacing on the ones down there---typically they are 16" or 24" apart---
It's pretty safe to guess that the spacing will be the same upstairs---
Then start looking for something that needs a joist bay for a chase---that will usually be a floor vent for heat--or even a wall vent for return air---remove the vent cover and poke a wire into a gap to see if you can feel the joist on either side----
then it's just a matter of math to find the joists in the location for the safe---
Or just use large wing bolts and forget about the joists---
Old 12-04-2012, 03:07 PM   #5
DIY staff
This sure is a home improvement! Enjoy----Mike-------
Old 12-04-2012, 03:40 PM   #6
I have worked on many homes where the spacing/location of the joists from 1st floor to second floor was different.
The idea of finding a floor register, they 'usually' mount to a joist side, so you find the joist, then calculate from there.
'usually' 16" but some are 19.2" and some are 24", and they can be altered for things like bathroom plumbing, chimneys and such.
Start with the 16" calculate over and find where you hope it to be.
Pull of baseboard, drill small hole near wall, which baseboard will cover. If you don't hit a joist no big deal. Try the other measurements. Or put a wire in the hole and feel over till you hit a joist.
replace hand ued support beam with a laminate support beam bwx1182 Building & Construction 1 10-24-2012 12:59 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Support I beam needed ThisOldH0use Building & Construction 28 05-16-2012 09:10 AM
My basement support beam rmugford Building & Construction 6 03-11-2010 09:24 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
