Old 12-28-2005, 09:32 PM   #1
How to find studs behind stucco
Hello,
I need to mount a garden house roll-up on the outside of the house--problem is that the outside is covered with stucco, and I'm not sure how to locate the wall studs...does anyone know of an electoronic stud finder that will work well through stucco?
Thanks to all responders-
Newbie1 is offline   Reply With Quote
Old 12-29-2005, 01:19 AM   #2
If you can find your studs on the inside of the wall , you could probably measure and find them on the outside. I'm big on removing a elect oulet cover and poking a thin screwdriver to either side and finding the stud that the box is nailed to and try to figure if that stud might be a 16 inch center stud. There are usually several other give aways as to the layout of the studs. HS..
K2eoj is offline   Reply With Quote
Old 12-29-2005, 10:22 PM   #3
Contractor
I use a Zircon.The levels are high, low, metal and it has an electrical alert.
Teetorbilt is offline   Reply With Quote
Can't find studs behind knotty pine paneling David S General Discussion 15 09-05-2010 06:56 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 11:04 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 04:48 PM
Stucco leak (long post) Pat B. General Discussion 1 03-24-2006 07:54 PM
