-   -   How to find studs behind stucco (http://www.diychatroom.com/f19/how-find-studs-behind-stucco-1535/)
Newbie1 12-28-2005 09:32 PM
Hello,
I need to mount a garden house roll-up on the outside of the house--problem is that the outside is covered with stucco, and I'm not sure how to locate the wall studs...does anyone know of an electoronic stud finder that will work well through stucco?
Thanks to all responders-
K2eoj 12-29-2005 01:19 AM
If you can find your studs on the inside of the wall , you could probably measure and find them on the outside. I'm big on removing a elect oulet cover and poking a thin screwdriver to either side and finding the stud that the box is nailed to and try to figure if that stud might be a 16 inch center stud. There are usually several other give aways as to the layout of the studs. HS..
Teetorbilt 12-29-2005 10:22 PM
I use a Zircon.The levels are high, low, metal and it has an electrical alert.
