Old 12-06-2008, 10:22 PM   #1
how to find rafter lengths
i know the rise bears the span but whats a easy way to get my rafter lengths like steping it off from my common or plum cut
countryboy is offline   Reply With Quote
Old 12-07-2008, 10:59 AM   #2
Pythagorean Theorem. Works for any right triangle.
Then take into account your angles, birdsmouth and overhang.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-07-2008, 11:03 AM   #3
I found a free 30 day trial rafter software called Easy Rafters and used it to layout my shed roof!
Check it out here! http://www.easyrafters.com/
Old 12-07-2008, 07:25 PM   #4
if you own a rafter square you can find a common multiplier that will get you your lengths. Take 1/2 the span of the building and multiply it by the multiplier. This will give you your length material. Also add in for the tail for the overhang. The multiplier will be found underneath the coresponding pitch on the rafter square. The numbers fall beneth the inch incraments on the body ( fat part) of the square.
Paul T. is offline   Reply With Quote
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
need some rafter help feralfreak Carpentry 5 07-30-2008 07:48 AM
rafter questions - structural rtoni Carpentry 11 09-13-2007 06:40 AM
rafter tail rott mohamie Roofing 8 09-27-2006 06:28 PM
