Old 02-29-2008, 12:15 PM   #1
How to Find Metal Telepost in Finished Wall
To fix a problem with some walls on the main floor, I am trying to locate the metal teleposts in the basement. The problem is that the walls are all finished.
I have the blueprints which should show me exactly where they are and I have been able to locate 2 of the 3 I am looking for. I have cut 3 holes in looking for it and can't find it.
Does anyone have a foolproof method of locating them without cutting any more holes? I have tried 2 different stud finders and one gives a slight reading when I tested it over one of the other telepost locations, but nothing on the wall where the telepost is supposed to be.
Any advice would be greatly appreciated.
Thanks in advance.
bhumeny is offline   Reply With Quote
Old 02-29-2008, 12:22 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Try measuring the distance of the two you have found, to calculate the distance of the third.
(Spacing between eachother, or spacing from foundation frost wall, etc...)
- Build Well -
Old 02-29-2008, 12:38 PM   #3
Good idea, but it won't work in this case.
The 2 I found are side by side due to a dropped ceiling.
There are no more on this portion of this wall. It is staggered from the other bearing wall.
Old 02-29-2008, 01:20 PM   #4
Custom Cabinet Maker
try a BIG magnet, Also the old school knuckle knock, you can find "solids" and then magnet it it sticks you got it.
skymaster is offline   Reply With Quote
Old 02-29-2008, 01:24 PM   #5
Jack of Some Trades
Wood Butcher's Avatar
usually the foolproof plan is to check the blueprints!
i don't suppose you are lucky enough to have drop ceiling that would allow you to poke your head into and look from above
Wood Butcher is offline   Reply With Quote
Old 02-29-2008, 01:26 PM   #6
Jack of Some Trades
here's a thought. could you be having the problem on the main floor due to the fact that there is no 3rd post?
Old 02-29-2008, 01:59 PM   #7
Got an idea form elsewhere.....
Drill a small hole and use a metal wire or coathanger to fish with.
If there is a post, you should be able to "hear" it.
Thanks for your ideas/comments.
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
