#1 |
How to fill in large hole under the corner of garage?
Hole was discovered by noticing a slight sag in the corner. From the outside one can put arm under the garage concrete floor. The corner of the garage is no longer attached to the footings. The structure is probably around 80 years old so the ground has settled. The adjoining concrete slab is cracked. Guy from a concrete raising company said that mud jacking would not work. due to cracked concrete and footings being separated. Has anyone ever found a solution to this problem? What do you think about putting wooden forms around the base of the garage then drilling a hole in the floor and pouring in a concrete leveling mixture?
Thanks! |
#2 |
I had to install footings under my concrete porch because I built a roof over it. Need to get footings down below the frost level.
I dug down 4 feet, and poured a concrete pad at the bottom. Then I installed a 12" Sono tube that had a step cut into it. The Sono tube rested half way under the concete wall. Then, I poured a sloppy mix of cement down the tube, filling it right to the top. Perhaps you can adapt this method of supporting your garage floor? |
| The Following User Says Thank You to Wildie For This Useful Post: | willfixsoon (09-30-2010) |
| Display Modes | |
| The 12-Gauge Garage | Jack Olsen | Project Showcase | 28 | 07-08-2012 11:21 PM |
| Plans for a garage loft (large set of shelving) | paul_2 | Carpentry | 10 | 08-16-2010 08:06 PM |
| Big hole in garage ceiling, laughing field mice. Help! | katiek71 | Building & Construction | 6 | 06-23-2008 02:45 PM |
| large mystery plywood panel in garage - any thoughts on this?! | joeyboy | General Discussion | 15 | 12-02-2007 04:01 PM |
| Sink hole under garage slab. | diggitydog | Building & Construction | 3 | 08-31-2006 01:49 PM |
