How To Fill This Gap? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 09:50 AM   #1
Rewards Points: 97
How to fill this gap?
Below is a picture of a gap found between the house (brick) and the wood trim. It's about 1in wide, and about 1.5in deep. This gap runs around the entire trim of the door. As you can see some of the sealant is coming off. I'll remove the old and reseal it. But how can I fill this gap in? What should I seal it with?
The biggest concern is the horizontal piece above the door. That gap can potentially trap water in there.
Please advise.
edta1 is offline   Reply With Quote
Old 06-26-2011, 10:03 AM   #2
the Musigician
DangerMouse's Avatar
Can you back away a few feet and retake a shot of that area?
DM
Old 06-26-2011, 11:38 AM   #3
Rewards Points: 5,334
The jamb the trim is connected to is too wide. Cut it flush with the brick or a little wider. Reattach the trim and caulk the sides. Install a metal flashing on top that goes behind the brick and over the top of the trim. Caulk under the flashing where it contacts the brick/trim interface.
Has the door frame shifted? A space of 1" is very large.
Ron
B. Franklin 1759
Kenmore doesn't fill properly svcsupply Plumbing 3 03-21-2010 05:15 PM
How to seal and fill sap veins before painting. fritzycat1 Painting 6 10-20-2009 11:13 PM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 09:37 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
