How To Fill BIG Hole Against Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 10:35 AM   #1
How to Fill BIG Hole Against Basement?
I have about a 10' x 10' x 8' deep hole right against my basement. There is a doorway to the basement. The sides of the basement and the sides of the hole are cinder block.
I am planning to block up the doorway and fill in the hole. Are there any steps I need to take to waterproof that area? What meaterial should I use to fill the hole? Do I need to put in drains or anything?
Fisher252 is offline   Reply With Quote
Old 08-10-2011, 01:45 PM   #2
anyone?
Old 08-10-2011, 01:59 PM   #3
Take the door out, fill the door hole with cinder block or poured concrete. Then install something like the Delta Foundation Membrane over the cement and then backfill
CountryCare is offline   Reply With Quote
Old 09-16-2011, 04:15 PM   #4
What should I fill the hole with? Dirt? Sand? Gravel? Concrete?
Old 09-17-2011, 07:13 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... Any of the above, but concrete would be expensive, 'n severe overkill...
Filling a large hole in basement! rotteneggz Building & Construction 4 10-01-2010 07:11 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Hole in middle of basement with fluid?? MikeyC Plumbing 17 08-12-2009 11:43 PM
taking out wood stove how to fill hole. bowanna03 General DIY Discussions 6 06-16-2009 10:46 PM
A hole in the basement wall handifoot Building & Construction 10 01-08-2009 10:14 AM
