How Far Do The Walls Need To Be From The Furnace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 10:58 PM   #1
how far do the walls need to be from the furnace
how far away do the walls need to be from the chance
smtisme is offline   Reply With Quote
Old 02-11-2012, 08:02 AM   #2
Rewards Points: 1,214
You need to find out the model number and follow the manufacturer's recommendations.
COLDIRON is offline   Reply With Quote
Old 02-11-2012, 08:34 AM   #3
Rewards Points: 12,790
Not the ansewer your looking for, but there has to be room to service the unit, there needs to be 5/8 fire rock on the walls, and enough free air flow getting to the furnace for combustion. A louvered door would do it.
I like to use a 36" door so if the unit ever needed to be replaced you do not have to tear down a wall to get it out.
Old 02-11-2012, 01:00 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
from what i remember it depends on what side of the furnace the wall is on.. on the air intake its 12". any side that has parts that need to be serviced. i.e burner. filter leave more space so the technician can get at it easily
woodworkbykirk is offline   Reply With Quote
Old 02-11-2012, 01:22 PM   #5
Rewards Points: 160
not sure if im right but for some reason i thought it was around 2 feet
jhack836 is offline   Reply With Quote
Old 02-11-2012, 01:41 PM   #6
Framing Contractor
Call YOUR building department. They will have your answer.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-11-2012, 02:38 PM   #7
Everybody's answers are incorrect, follow Manufacturer's instructions.
The Following User Says Thank You to COLDIRON For This Useful Post:
mae-ling (02-12-2012)
Old 02-12-2012, 12:03 AM   #8
Registered User
Rewards Points: 4,890
The clearances may be inside the unit or on the service door inside face (otherwise follow post #2 and #6). Your local Building Department may have specific requirements for the combustion air supply, ducting, etc.; pp. 2, and 3, not just a louvered door: http://www.mybuildingpermit.com/Insp...0checklist.pdf
Gary
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 09:13 AM
How close can i build walls to my furnace? hello18 HVAC 14 02-02-2012 06:32 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
