Old 08-03-2012, 09:47 PM   #1
How far can a 2x10 be spanned without center support?
the 2x10's are being used to support decking on a 14ft span, and would serve as floor joists.
Thanks for any feedback
dbldee20 is offline   Reply With Quote
Old 08-03-2012, 09:52 PM   #2
GBrackins's Avatar
first are you talking about a beam or joists? also the species of wood comes into play.
here is a link to the Prescriptive Residential Wood Deck Construction Guide which is based upon the 2009 International Residential Code. Your code may differ, contact the building department to verify
http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
this will give you the maximum spans based upon the species of wood used, and the loads they must transfer to the ground. Pretty much anything you want to know about deck construction is contained within this document.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
dbldee20 (08-06-2012)
Old 08-03-2012, 10:11 PM   #3
I'm pretty sure it's yellow pine from south carolina. that seems to be what most sellers in my area carry. #2 prime treated lumber is what's on the tag.
The 2x10's are being used as floor joists and not the beams, which are notched into 6x6 posts.
Old 08-03-2012, 11:25 PM   #4
GBrackins's Avatar
should be table 2 in the Guide, just pick your spacing and it'll give you your maximum length
Good luck!
Gary
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 09:52 PM
Floor Support Beam SlipperyPete Building & Construction 3 12-04-2006 06:55 AM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
