How To---Draw An Arch-- - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 06:27 PM   #1
how to---Draw an arch--
how to mark out and make an 8feet wide arch opening by 5 feet high
big bud is offline   Reply With Quote
Old 10-25-2011, 06:40 PM   #2
Framing Contractor
[QUOTE=big bud;756659]how to mark out and make an 8feet wide arch opening by 5 feet high
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-25-2011, 06:57 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
lay it out on some 1/2" plywood on the floor, mark the arch cut it out with a jig saw, rip some 2x4 down to 2 1/2" and cut blocks which will act as spacers to create a 2x4 wall... fasten them so they are flush to the opening of the arch..
woodworkbykirk is offline   Reply With Quote
Old 10-25-2011, 07:03 PM   #4
DIY staff
Rewards Points: 7,174
I had a link to this but the link went dead----so here goes.
You will need 4 finishing nails and two thin sticks of wood (For you--about 5 feet long.)and a hot glue gun.
Drive in one nail in each outside corner of your arch --leave them sticking out so your sticks can ride on the nails. (8 feet apart)
Find the center (4 feet) Measure up to the top of your arch (5 feet) Drive another nail there.
Measure the same distance above the right hand nail (5 feet) Install the last nail.
Lay one stick against the lower left nail and the center nail--then lay the second stick from the center nail to the high right hand nail----
Hot glue the sticks together where they overlap at the center nail.
You should have a boomerang shaped stick----
Remove the top right nail----
Place a pencil into the crotch of the stick---and slide the stick along the nails while drawing the arch.
Perfect arch every time.
Old 10-25-2011, 07:39 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What style arch?
Roman, tudor, gothic, morish, parabolic, segmental?
Old 10-25-2011, 08:39 PM   #6
DIY staff
Originally Posted by Bud Cline View Post
What style arch?
Show off
Old 10-25-2011, 08:47 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Show off
I couldn't remember them all I had to look them up.
The Arch is complete Snav Project Showcase 6 09-27-2011 03:09 PM
How to build a wooden arch? pergola101 Building & Construction 1 09-26-2011 11:02 AM
Voltage sag or VD. Where do they draw the line in the sand? viper Electrical 43 05-18-2011 02:56 PM
Red bricked arch over front doors (leaking)! doityourselfno Building & Construction 7 06-04-2010 04:26 PM
Matching an arch JRiegler Carpentry 17 12-23-2009 06:07 AM
