How Does Drain Pipe Around Foundation Footing End? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 02:28 AM   #1
How does drain pipe around foundation footing end?
I always have a question which I don't have a clue:
How those drain pipes around foundation footing end? Run into a pit? Run to day light? Or connect to sewer system?
Does anyone who has experience about this? Thanks! :D
pttcc is offline   Reply With Quote
Old 09-19-2010, 08:43 AM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 802
There are several choices, all of which should be made by a design professional.
Best choice involves HUD's Best Practices regimen. That can be found here starting on page 46: http://www.huduser.org/publications/...sturehomes.pdf
Next best, connect it to a properly sized sump and pump, and discharge it to daylight or an approved stormwater connection (town will have a say here).
Next best, connect it to a properly sized on site dry well through properly sized pipes.
Least desireable is not having a system.
Aggie67 is offline   Reply With Quote
The Following User Says Thank You to Aggie67 For This Useful Post:
pttcc (09-19-2010)
Old 09-19-2010, 09:46 AM   #3
Old School
Willie T's Avatar
You just got better advice than I could ever offer.
Willie T
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 01:18 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Major drain issue... what is this pipe? moneymgmt Plumbing 9 08-04-2009 11:53 PM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 01:07 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
