How Do You Set Posts For A Shed On A Hill ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2008, 11:50 AM   #1
How do you Set posts for a shed on a hill ?
I have a small 8x8 shed I want to build on the side of a hill and I am unsure if I should set the posts completely in concrete or just at the base and then fill in with back fill (dirt,shale). The incline for one side of the shed on the slope to become level is slight , maybe the post will come above the surface 1 foot. I was planning on placing 1 post on each corner. 4 in total. 2 at about 1 foot above the surface and the other 2 just above the surface. The ground freeze depth here is 18". So should I place gravel underneath the posts and pour concrete around the posts to the surface or other wise.Is it essential for the ground to be dry to pour concrete ? The ground being saturated is a concern. I realize this structure is small but should I place a central post to brace the weight distribution or will the corners be sufficent as I am spacing the floor joices every 12". I would greatly appreciate any advice. Thanks.
Lance is offline   Reply With Quote
Old 03-05-2008, 06:29 PM   #2
hvac/refrigeration
If it were me, I would go to local home store of your choice lowes or home depot and pick up some cylindrical tubes. Dig Down minimum 18'' until you hit solid ground. Set tubes in the ground and pour full to your joist level minus green plate or if using green wood set directly on top of concrete. I would at least get it up high enough so you have no water saturation directly on the joist.
Ground being wet doesn't really matter as long as you get down to solid ground and set the tubes.
As far as using post. You would have to set them on top of something solid, not just stuck in hole and concrete around them. If going this route dig the hole, pour concrete above ground level, set risers on top of pier and underneath the post.
metal-maniac is offline   Reply With Quote
Old 03-05-2008, 11:45 PM   #3
Rewards Points: 5,336
Set the sonotubes to a depth of 24". You want to set them below the frost line, not at the frostline. Insert one of the Simpson connectors into or on top of the sonotube. Lay the framing lumber so it sits in the connectors off of the concrete.
Ron
Old 03-08-2008, 12:17 AM   #4
Rewards Points: 150
How bad is the slope and the soil? What weight is going in the shed? Do you need to tie it into the hill with footings?
I would bell out the bottom of the sono tube formed holes.
Set the piers to hold the wood minimum of 16 inches off the soil and plan on a stair or ramp.
kgphoto is offline   Reply With Quote
Replacing covered porch support posts yousah Remodeling 4 09-30-2007 01:15 PM
Support posts for 12' high deck hotchkiss Remodeling 3 09-05-2007 07:32 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 10:56 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 07:46 AM
building a shed on a sloped hill tom1st Building & Construction 5 08-03-2006 08:22 PM
