Old 09-21-2009, 02:04 PM   #1
Question
How do you replace on interior door with a wider one?
I'm trying to figure out the best way to widen a door frame from 24" to 30" so I may hang a 28" door. I already have the new door and have removed the old bifold door. The door frame is on a non weight bearing wall so must I remove the old frame all together or is there some alternative I'm unaware of?I'd like to know my options before I punch holes in the wall...
Bawborkian1 is offline   Reply With Quote
Old 09-21-2009, 02:27 PM   #2
The only difference between the framing required for a door in a load bearing wall and a non-load bearing wall is the necessity of a load bearing header.
remove the whole jamb of the old door.
measure and remove wall board to the new rough opening size.
install the stud and trimmer to the new location.
replace the header board with an appropriate replacement.
fasten and mud wall board as needed.
install new door/jamb.
piece of cake!
mics_54 is offline   Reply With Quote
Tags
door replacement, hanging door, interior door, widen frame
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 07:37 AM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
need to replace floor decking under furnace pdsullivan HVAC 6 02-21-2008 02:42 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
