How Do You Remove A Pocket Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2008, 03:06 PM   #1
How do you remove a pocket door
how to remove a pocket door
billangov is offline   Reply With Quote
Old 10-11-2008, 03:29 PM   #2
the Musigician
DangerMouse's Avatar
completely removing the track and all or just lowering the door for repair/replace? there should be 'hooks' on the supports that unclip to release the door.
DM
Old 10-11-2008, 03:39 PM   #3
Registered User
Termite's Avatar
Depends on the door, but most of them do come out. You may have to remove the jamb stops if the opening has them to get the door all the way out. Most of them hang from rollers similar to sliding closet doors.
Old 10-11-2008, 07:26 PM   #4
I agree,I have almost always had to remove the 1 top and side stop to get it out without dinging it up.Cut the caulk gently with a razor knife between the jamb leg and the top first.Then put a small flat bar/flat prybar and gently work your way up and down to pry them off.Be careful not to break them,it's not hard to do.Hope this helps.
Mark
S&S Custom Trim &Paint is offline   Reply With Quote
pocket door coming off track jimmy21 Building & Construction 6 10-06-2008 02:28 PM
Pocket door and tall floor...oh my wem Remodeling 3 03-24-2008 05:45 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
How to remove interior sliding (pocket) door Horst Remodeling 7 12-13-2007 12:13 AM
