How Do You Remove Mortar From Brick? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 07:01 PM   #1
Question
How do you remove mortar from brick?
I recently repaired my front steps by replacing a few rows of clay brick and added bluestone treads. The mortar got a little messy and I can't seem to remove all of it. It actually looks like crap. I have tried various muriatic acid amounts in water and the old brick scrubbing trick. Nothing works and I'm going nuts about trying to finish it properly. What can I do??? Is there a special tool that I can use?
JAYinMA is offline   Reply With Quote
Old 09-17-2011, 07:10 AM   #2
Rewards Points: 5,332
The time to clean the mortar off the brick is soon after you finish the job. At this point, you can try powerwashing the residue off or using a chisel to get the globs off and then try the acid again. Grinding is a possibility, but the damage you can do usually outways the benefit.
Ron
B. Franklin 1759
Tags
brick , mess , mortar , remove
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 07:32 PM
how to remove mortar glue residue on slate tiles aggiejess7 Flooring 5 05-13-2009 04:00 PM
Can I dye existing brick mortar? Foo by Tore General DIY Discussions 2 10-30-2008 07:03 PM
