How Do You Mount It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2008, 10:27 PM   #1
how do you mount it?
I am looking at putting up some walls in my basement. How do I mount the framing to the concrete floor?
=Stephens= is offline   Reply With Quote
Old 01-16-2008, 10:42 PM   #2
That ADA Guy
I have a .22 caliber powder gun that shoots nails into the floor, but you can use tap-cons, sold at the home centers or hardware stores, and they come with the drill bit you need. I would use the 1/4".
Jeff_of_all_Trades is offline   Reply With Quote
Old 01-17-2008, 08:14 AM   #3
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Like jeff said, either way
Kingfisher is offline   Reply With Quote
Old 01-17-2008, 08:50 AM   #4
Thanks for the help.
Old 01-17-2008, 10:03 AM   #5
12 year IBEW member
I Know a carpetner who just uses a square nail that is designed to be pounded in to the concrete with a hammer ( I use a 2 lb hammer) and then he also uses pl-200 or 400 which ever one is rated for the job. this way no special tools for a job that you may never use again. IMO drilling concrete without a A real hammer drill is a pain in the . just be sure to use green treated lumber where in contact with the concrete floor.
heavyduty is offline   Reply With Quote
Old 01-17-2008, 10:12 AM   #6
Rewards Points: 1,910
All above works. If using tapcons you'll probably find that the drilling is very difficult unless you use that hammerdrill Heavyduty described.
You don't say where you're located. There are a few locations such as in some parts of Colorado where floating walls are required in basements. That requires a different technique. Check with your local building/permit department to see if anything special like this is required.
Old 01-17-2008, 10:20 AM   #7
Talk nice to it. Take it out for dinner. Don’t just sneak up and hop on…
RYANINMICHIGAN is offline   Reply With Quote
Old 01-17-2008, 12:22 PM   #8
I live in Nebraska. I will find out what the requirements are here. Thanks for the information
Old 01-18-2008, 06:07 PM   #9
That ADA Guy
I forgot to mention the hammer drill part. sorry. Yes that will definitely help
Wall mount toilet warnerww Plumbing 3 07-04-2011 08:01 PM
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 08:23 AM
Flush Mount Ceiling Fans argana Electrical 6 01-05-2008 05:43 AM
How to mount a ceiling fan to an overhead beam rtyui2 General DIY Discussions 3 12-17-2007 03:29 PM
Plasma Mount in Family Room Built-Ins taysdad Home Theater 3 09-24-2007 08:59 AM
