How do you make a pattern for an inside curve?
I have a fiberglass shower stall and the bottom tray is too shallow to keep the shower curtain from blowing out. I want to put a short "wall" of 8" x 1" PVC at the bottom but where the walls come up from the threshold has a slight curve. How to I make a pattern for this so that the PVC fits in perfectly?
Any suggestions? I tried to guestimate with paper but it was so imperfect that I was afraid I'd be using tubes of caulk to get it sealed well.
One more question... before I use silicone caulk on the inside and outside, should I glue it in place first and if so, what type of glue? Loctite makes a power grab for fiberglass tub surrounds...???
thank you
