How Do You Make A 90 Degree Angle On A Fence - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2009, 05:14 PM   #1
how do you make a 90 degree angle on a fence
how do you make a 90 degree angle on a fence?
sherrybjjay is offline   Reply With Quote
Old 05-02-2009, 05:34 PM   #2
Rewards Points: 156
umm
I'm not sure where to begin here...
jayp is offline   Reply With Quote
Old 05-02-2009, 06:23 PM   #3
Rewards Points: 1,016
It depends on whether you are going up or down at the time.
Old 05-02-2009, 07:05 PM   #4
concretemasonry's Avatar
Rewards Points: 2,578
Are you sure the property corner is really degrees. Usually, the fence follows property lines.
Dick
concretemasonry is online now   Reply With Quote
Old 05-02-2009, 07:33 PM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Same as an 85 degree angle, only 5 more.
I hate signatures.
Mort is offline   Reply With Quote
Old 05-02-2009, 07:56 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
please explain what you are looking for.
If you are asking how to determine a 90º angle, that is easy. If you are asking how to install a corner for a fence, still no problem. Just need to know what kind of fence.
Old 05-02-2009, 08:49 PM   #7
the Musigician
DangerMouse's Avatar
first, i'd get my square and be sure the blade is 90 degrees, then set the fence and run the board.
but hey, i'm a carpenter.....
DM
Old 05-02-2009, 08:50 PM   #8
Old School
Willie T's Avatar
This example (using 3- 1/2" posts) gives you two choices.
One is with 8' panels.
The other is with 10' panels
The measurements are pulled off the inside corners of the posts.
Shortly, I'm sure someone will post to explain to you how to do a Pythagorean Theorem calculation. It's simple:
where c represents the length of the hypotenuse, and a and b represent the lengths of the other two sides.
In words: The square of the hypotenuse of a right triangle is equal to the sum of the squares on the other two sides.
That's the way we were taught in school. In the field we shorten it to using three numbers that all carpenters memorize... 6, 8, 10. (And some guys use different numbers than other guys... perhaps, 3, 4, 5 or some other combination.)... it still works out to give you a 90 degree angle.
But this drawing will give you the numbers on a typical fence setup.
Willie T
wood fence post farrington135 Building & Construction 11 05-17-2011 03:32 PM
Fence Problems Shadow Landscaping & Lawn Care 3 02-18-2008 03:26 PM
Crooked Fence - Grrrrrr Dallas Building & Construction 1 12-04-2007 07:18 PM
Privacy Fence Gate Dallas Carpentry 8 11-20-2007 09:12 PM
Make a cyclone fence safe for my pups not to dig out under it. dlpeterson@chartermi.net Introductions 4 07-27-2006 01:43 PM
