-   -   how do you make a 90 degree angle on a fence (http://www.diychatroom.com/f19/how-do-you-make-90-degree-angle-fence-43674/)
sherrybjjay 05-02-2009 04:14 PM
how do you make a 90 degree angle on a fence?
jayp 05-02-2009 04:34 PM
umm
I'm not sure where to begin here...
vsheetz 05-02-2009 05:23 PM
It depends on whether you are going up or down at the time.
concretemasonry 05-02-2009 06:05 PM
Are you sure the property corner is really degrees. Usually, the fence follows property lines.
Dick
Mort 05-02-2009 06:33 PM
Same as an 85 degree angle, only 5 more.
nap 05-02-2009 06:56 PM
please explain what you are looking for.
If you are asking how to determine a 90 angle, that is easy. If you are asking how to install a corner for a fence, still no problem. Just need to know what kind of fence.
DangerMouse 05-02-2009 07:49 PM
first, i'd get my square and be sure the blade is 90 degrees, then set the fence and run the board.
but hey, i'm a carpenter.....
DM
Willie T 05-02-2009 07:50 PM
1 Attachment(s)
This example (using 3- 1/2" posts) gives you two choices.
One is with 8' panels.
The other is with 10' panels
The measurements are pulled off the inside corners of the posts.
Shortly, I'm sure someone will post to explain to you how to do a Pythagorean Theorem calculation. It's simple:
http://upload.wikimedia.org/math/1/4...baf74d63f9.png where c represents the length of the hypotenuse, and a and b represent the lengths of the other two sides.
In words: The square of the hypotenuse of a right triangle is equal to the sum of the squares on the other two sides.
That's the way we were taught in school. In the field we shorten it to using three numbers that all carpenters memorize... 6, 8, 10. (And some guys use different numbers than other guys... perhaps, 3, 4, 5 or some other combination.)... it still works out to give you a 90 degree angle.
But this drawing will give you the numbers on a typical fence setup.
