How Do You Know If A Wall Is A Load-bearing Wall ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2008, 01:11 PM   #1
Rewards Points: 150
How do you know if a wall is a load-bearing wall ?
Never mind, I googled it. But I am still not sure if it is better or easier looking at the blue prints than trying to track all the wood beams, and loads. Would the blue print (if any) be straight forward in identifying a load bearing wall?
gante is offline   Reply With Quote
Old 02-20-2008, 05:55 PM   #2
Rewards Points: 6,652
Usually, if you remove it and your house starts making noises, you will know then.
Old 02-20-2008, 07:03 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
Actually you could look in the attic. If the ceiling joists run 90 degrees to the wall, then it COULD be load bearing. The reason I say could be is if there are truss, then the only load bearing should be on the outer walls.
USP45 is offline   Reply With Quote
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 07:12 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
