How Do You Get Rid Of Construction Dust? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2013, 11:01 AM   #1
How do you get rid of construction dust?
I am a house flipper and am wondering what is the best way to remove dust? I've been looking at dust collectors but am wondering if those are more like vacuums or can you turn it on and just let it sit there to collect dust?
jclee is offline   Reply With Quote
Old 01-18-2013, 11:05 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,104
combination of things.. creating negative pressure by having a high velocity fan blowing out a single open window while the rest of the windows remain closed creating negative pressure.
shop vacs set up with hepa bags. along with a thorough cleaning
woodworkbykirk is offline   Reply With Quote
Old 01-18-2013, 11:11 AM   #3
Rewards Points: 13,444
The trick is to keep the dust down as your working.
Open a window remove screen and have a cheap box fan blowing out, running a shop vac with a drywall bag over the filter near the tool your using.
Laying tarps on the floor, putting plastic up over the HVAC vents or shutting it off.
Putting plastic up over doorways.
Old 01-18-2013, 11:18 AM   #4
what about air purifiers or something like ...
http://www.globalindustrial.com/p/ja...FelFMgodRB4ACQ
Old 01-18-2013, 11:25 AM   #5
To make an omlet you have to crack some eggs.
I've been working on homes most of my life and have never once seen anyone use an air filter.
Just going to have to get over the fact there's going to be some dust.
For a complete over haul we just wait until the end of the job to do the white glove treatment.
Old 01-18-2013, 11:30 AM   #6
I understand that, but i'm concerned for my health and my workers health, so i'm looking up solutions.
Old 01-18-2013, 11:33 AM   #7
That's why they make dust mask.
Old 01-18-2013, 11:42 AM   #8
yes, we wear those, but still, there are times when we need to take them off. anyways. i think ive found solutions. there are renovation filters out there
Old 01-19-2013, 09:44 AM   #9
Rewards Points: 166
You can buy small portable dust collectors that can be hooked up to you tools (if they have dust ports). I personally don't think they work great, but it's something.
A common and cheap woodworkers trick is to use a large box fan with a furnace filter against the intake side. That will pull out a good amount of airborne dust, but not all.
You are not going to eliminate dust without installing a serious dust collection system and obviously you can't do that in a house you plan to flip.
Go to a woodworkers forum and read some of the threads on dust collection. It's a much bigger task than it seems on the surface.
dftc is offline   Reply With Quote
Old 01-19-2013, 10:49 AM   #10
DIY staff
Rewards Points: 7,174
This advice is the standard of the industry---follow this and you will be in good shape.
woodworkbykirk (01-20-2013)
Old 01-19-2013, 11:15 AM   #11
Rewards Points: 4,578
have vacs for conc prep tools ( circle saws, grinders, chipping guns ) that work well however they're north of $ 1,500 - deal breaker for most,,, cheaper models run on 15a, 110 v @ $ 1,500,,, 208 & 440v are in the $4K - $6K range,,, naturally all tools have dust shrouds,,, not much help for drywall & sawdust, tho
Old 01-20-2013, 09:06 AM   #12
AHH, SPANS!!!
Rewards Points: 1,166
it will most likely be a room by room basis if drawing air out of one draw window. no need to set up a fan in one room and draw dust through the entire house to blow it out the one fan window. leave windows up and draw air from the room being worked in, when changing rooms change fan locations. if it is winter time hope you like the cold air...
hand drive is offline   Reply With Quote
Old 01-20-2013, 04:55 PM   #13
forgot to mention this earlier - zipwall & zipdoor - we've used both & they work great ( no financial interest ),,, we also use 2 vacs in tandem occasionally,,, both w/o filters just to carry dust 30' or so out a window/door
The Following User Says Thank You to stadry For This Useful Post:
Old 01-20-2013, 06:27 PM   #14
if its gonna be room by room. really conc is right. you have to seperate the rest of the house from the work.. mask off the doorway with plastic along with any or all warm air feeds or cold air returns
So, what type of construction is my house Tonglebeak Building & Construction 8 12-01-2012 10:45 AM
Window Sill Rot, New Construction Replacement? mpg9999 Windows and Doors 8 11-18-2012 07:08 AM
interior construction project question kindofsudden Building & Construction 5 11-07-2012 09:51 AM
white or clean dust 1989gta HVAC 7 09-06-2012 05:05 PM
Sheetrock dust under carpeting in basement... Please help. ben319 Building & Construction 7 09-15-2009 03:35 PM
