How Do You Find The Wall Studs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 11:43 PM   #1
Rewards Points: 358
how do you find the wall studs?
what am I missing here, sounds so simple yet so hard haha. when putting up some cement plank you need to nail it to the stud, how do i find the stud if the sheathing is covered in a vapor barrier? my house is 70 years old so the studs are not at predictable spacings.
maybe I need to make some measurments of each stud and make some marks after I put up the tar paper?
Thanks!
cbzdel is offline   Reply With Quote
Old 07-01-2011, 01:10 AM   #2
Rewards Points: 1,092
First, where are you, and where in the house are you installing the cement boards? Are vapor barriers required by code in your area? They are generally being abandoned in most places on earth. Now is the time to remove it if you don't have to have it (by code) and air seal instead. If you ever run air conditioning, the vb can be disastrous. Finding studs w/out nails won't be fun w/out an electronic stud finder.
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Finding wall studs jmfma General DIY Discussions 8 01-03-2010 05:06 PM
Repairing rotted studs against exterior wall sleepyscout Carpentry 11 07-01-2009 01:31 PM
