How Do Put A Deck Beam On Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 02:48 PM   #1
how do put a deck beam on posts
my posts are 7 feet high and i was plannibg to put my beam on the posts, but how do i get a 4"x 10" by 30 feet beam in the air
swift123 is offline   Reply With Quote
Old 06-22-2012, 03:07 PM   #2
Willing to listen
Rewards Points: 221
Friends / neighbors + some beer might work. That's my usual tactic.
Are you going to place that beam into a notch on the posts?
Done That is offline   Reply With Quote
Old 06-22-2012, 05:53 PM   #3
Rewards Points: 13,446
Is this a soild 4 X 10 beam? You would be better off with 3, 2X's instead, even then 30' is to long for a span between the post, and use 6 X 6 post, not 4 X 4's.
Old 06-22-2012, 06:52 PM   #4
7' isn't that high. No ladders involved. Like Done That said, couple neighbors and a few beers sounds like the best option.
CopperClad is offline   Reply With Quote
Old 06-24-2012, 12:09 AM   #5
Registered User
Rewards Points: 5,466
As Joe said, you do know a 4x10 cannot span 30'...... you need this for sure: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
P.S. Welcome to the forums!
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 09:56 AM
Adding posts and beam to floor for aquarium Vincer Building & Construction 4 03-23-2011 02:47 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Replacing existing load bearing deck posts Tubachin Building & Construction 2 09-07-2010 04:33 PM
Setting a deck beam directly on footings ovahimba Building & Construction 1 01-10-2008 01:57 PM
