How Do I Wrap This Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 01:15 PM   #1
Rewards Points: 178
how do I wrap this deck
What's the easiest, fastest yet relatively attractive way to wrap this deck (see attached photos)? The main goal here is to hide the brackets, hide the decking ends (or whatever its called) on the landing and stairs and get this bad boy stained or painted ASAP.
how do I wrap this deck-20130818_110615.jpg   how do I wrap this deck-20130818_105412.jpg
anuvanoob is online now   Reply With Quote
Old 08-19-2013, 09:24 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
you could put a skirt board along the sides but the decking does not overhang so the skirting will have water intrusion and you will see the skirting from above. it looks good as is from the pic you posted, seen a lot worse...
hand drive is offline   Reply With Quote
Old 08-19-2013, 11:02 AM   #3
Rewards Points: 6,179
Make a wood flower box that tops off level with the decking.
Make sure you first go buy two long plastic planters. and build your
flower box to incorporate the planters.
Attach the wood securly to the flower box (make sure you either
droll lots of holes in the bottom for the water to drain out, or
make the bottom out of slats.
Make two nice decorative decorative brackets and attach then to the
two decking uprights.
Fill the plastic lined containers with potting soil and plant
with plants or flowers. Purple palace is great, it's a perrenial,
actually a semi-evergreen in your zone.
Also vincqa vine is another of my favorites, mixed with some
flowers.
Two Knots is online now   Reply With Quote
Old 08-19-2013, 11:20 AM   #4
Here are the planters I'm referring to.
They come in different size, make your wood planter
high enough so that the top is not visible.
The left and right side is Purple Palace, comes back
every year in March and looks great up until
a hard freeze.
With nice beefy brackets coming off the legs, it will
be attractive and still give you access to under the deck
to keep it clean.
I know, all three should be green...
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Wrap around deck Melanie1 Building & Construction 4 09-16-2010 07:06 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
Renos for tenants, in older home for function, privacy, safety & pride in there liv willowgirl Building & Construction 21 01-16-2010 01:04 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
