How Do I Waterproof A Sill Under Grade Level? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 08:22 AM   #1
How do I waterproof a sill under grade level?
The level of my bluestone patio is 6" higher than the poured foundation wall. The sills and rim joists rotted. I've jacked up the joists and replaced the sills and rim joist with pressure treated lumber.
___________________
My question now is how do I waterPROOF an wood undergrade sill and rim joist?
___________________
The failed construction method was to pour a 4" thick patio concrete pad right up against the stucco wall with the wood framing behind it. Maybe a crack appeared between the concrete pad and the wooden rim joist and allowed water to penetrate?
A contributing problem might have been that gutters were attached to drainage piping that carried water under the patio to the other side. All good except that the drainage pipe was full of predrilled holes - like a perimeter drain. Maybe the gutters SUPPLIED the water that rotted the sills?
Hope that the pictures came through OK and that this problem peaks your curiosity. I'll try to remember to post followups so that others can learn from this experience.
Thank you in advance.
How do I waterproof a sill under grade level?-sill-rot.jpg   How do I waterproof a sill under grade level?-sill-rot-2.jpg
Semi - pro is offline   Reply With Quote
Old 03-14-2010, 09:00 AM   #2
kwikfishron's Avatar
Rewards Points: 796
How far does the rot go past the door? Does it run the entire length of the house? In what I can see in your picture your grade doesn't look like It's above the bottom of the stucco. Plate line our the top of your foundation "should" be a inch or so above the bottom of the stucco, is it?
Ron
kwikfishron is online now   Reply With Quote
Old 03-14-2010, 09:13 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
short of rebuilding all the affected walls using materials that can be directly buried in the ground,you can't really waterproof this detail
you should excavate that whole area to at least 6-8'' below the foundation
sloping the excavated area away from the house,install a retaining wall and proper drainage...may as well fix it right and be done with it
Tom Struble is offline   Reply With Quote
Old 03-14-2010, 09:30 AM   #4
The rot extends the entire back side where the patio meets the house, about 48'. I've removed the bluestone and jack hammered the patio out 24" from the house. The hole shown in the picture is the missing sill on the bottom. The stucco, now removed to above the rim joist, used to extend to about the sill level.
Ron
Old 03-14-2010, 09:35 AM   #5
Rewards Points: 796
How about a new pic. of what it all looks like now.
Old 03-14-2010, 09:42 AM   #6
I'd need to remove the entire patio area (16'x48') to get a drainage grade. I'm reluctant to destroy the patio before I explore other options.
I suspect there is a solution to this problem since I'm not the only one out there in the Northeast with a patio level close to inside floor level.
How about it you pool owners out there?
Old 03-14-2010, 09:46 AM   #7
maybe a 3' wide french drain system at house leaving finished gravel flush with patio. then its just a matter of a good waterproofing system at house
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
Semi - pro (03-15-2010)
Old 03-14-2010, 10:15 AM   #8
waterproofing a wood/stucco house at the bottom,has the potential to become the ''rubber boot''scenario,if your going to dig a 3' trench anyway you may as well fix the grade the way its supposed to be
lotta work for sure,but this is your house not a garage or a shed out back
Old 03-14-2010, 11:36 AM   #9
Rewards Points: 796
I’ve been a siding contractor/ builder on the Oregon Coast for to many years and have seen this problem many times. Code around here is that grade be no higher than 6” below the top of the foundation. Since you don’t have that and your hoping to find a solution without excavator ripping your yard up and regardless how you choose to put your new ditch back together with a number of different drain options your ultimate goal is to
“Protect The House”
and not completely rely on a drain system in this case. Since you said that you have already ripped up some stucco this is what I would do and have done many times.
After you have repaired the framing run a piece of Stainless Flat Stock over the sheathing however wide it needs to be to lap over the foundation 3-6” and above grade at least 6” and under the felt or membrane of the stucco. I’d even run a big fat bead of Blackjack or something against the foundation under the flashing so water can’t seep up.
In the area of those big glass doors you need a “Stainless Door Pan“.
If your not familiar with them It’s a cap for the bottom of the doors. It covers the entire opening and flanges up about ” on the sides and on the inside of the house and flanges down about 1 ” on the outside of the house. It’s that outside flange were you will tuck the flat stock flashing under. Yes you will have to remove and re-install the doors to do this but it’s the only way to positively keep water from getting to the sheathing. A pan can be made up at any local sheet metal shop. You defiantly want to measure for the pan twice or thrice, it needs to be right. You want it be a little wider than the door but not to wide to be tight in the framing and just slightly wider front to back so you have room to get your other flashing under the front flange.
I would definitely go Stainless Steel on all of it, Galvanized will fail over time in this application. If you have to go galvanized at least sheet the affected part of the wall with treated.
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 03-14-2010, 11:58 AM   #10
[quote=
How about it you pool owners out there?[/quote]
probably wondering how to fix their house
The Following User Says Thank You to Tom Struble For This Useful Post:
Old 03-15-2010, 01:29 PM   #11
I promised updates as they come along:
I spoke today to Randy in tech support at Marflex 513-422-7285. He suggested a waterproof coat to both the foundation and wood. Then cover with a peel and stick waterproof membrane (that sounded like Grace ice and water shield but for foundations). His products are distributed through AHHarris locally. I asked if I could use his name on this website and he said yes. I tiold him if the products don't work I'll post that too and he still seemed enthusiastic.
He also agrees that the perforated drains should be replaced with solid pipe and that additional perforated pipe be installed as a separate system. This way roof water through gutters can not be introduced to the gravel under the concrete patio layer. It also means I need another day with HD's rental jackhammer - UGGG.
He seemed very confident in his recommendation and offered to write a letter of suitability, if necessary, that might be useful for a building inspector or in the eventual sale of the house.
Next updates will be what is actually done and if it works.
Old 03-15-2010, 05:08 PM   #12
Rewards Points: 796
That is basically the same thing I told you, the only difference is using is the ice and water (the product he’s a rep. for) instead of the stainless steel flat stock. Stainless Steel is forever (or at least a lot longer than we’ll be around) don’t get me wrong the other is good stuff but can tear, especially with rock against it. I’d price it both ways.
I’ll still always be adamant about door pans. When water blows up under the sill what keeps it from getting behind the paper and to the sheathing, a bead of calk? I can’t count how many doors I’ve pulled and rotten sills (and more) I’ve replaced that wouldn’t have been necessary if there was a pan. It’s a different thing if you have a big overhang like in most entry’s so that the weather isn’t pounding the door.
We have hurricanes on the Oregon Coast but for some reason they just call it rain.
Old 03-17-2010, 09:04 AM   #13
Rewards Points: 4,738
miradrain & asphalt cement,,, for a sketch, either tremco or my w-site IF its not too late,,, note - IF you don't provide a pathway for the water to drain, it'll just sit there & the conc'll suck it up thru capillary action.
according to aci, conc's NOT wtrproof til compressive reash's 5,000psi.
good luck !
Tags
patio , sill rot , waterproof sill
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-01-2010 11:21 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Door Sill Flashing Pondo13 Building & Construction 1 08-19-2009 06:15 AM
Crooked window sill in old wood house bofusmosby Carpentry 36 04-13-2009 08:34 PM
Outdoor outlets jamiedolan Electrical 1 01-17-2009 11:15 AM
