How Do I Stop Water From Getting Under The Floor Of My Plastic Lifetime Shed. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 03:48 PM   #1
How do I stop water from getting under the floor of my plastic Lifetime shed.
How do I stop water from getting under my plastic shed? I have tried to seal (caulk) around the outside where the plastic floor sits on the sub-floor (which is 3/4 inch plywood on 2 x 6's and is slightly larger than the the shed floor). No water gets into the interior of the shed. But, even after a small rain, water accumulates on the plywood sub-floor under the shed plastic floor and I know it will eventually rot.
Any ideas would be greatly appreciated!
Ckeith is offline   Reply With Quote
Old 08-30-2010, 11:21 AM   #2
Rewards Points: 4,656
guess i'd be raising it off the ground to provide more airflow under it 1st,,, roofing cement's better than caulk in this instance,,, could it be the ply's porous & wicking wtr inside ?
you might try some flashing, too.
Old 08-31-2010, 09:33 AM   #3
Thanks for the reply. Perhaps the glue will work.
Old 08-31-2010, 09:36 AM   #4
glue ? who mentioned that ? ? what glue could you use ?
Old 08-31-2010, 11:54 AM   #5
My apologies - the reference was to roofing cement.
Base for Lifetime (plastic) storage shed proofer Building & Construction 13 07-03-2015 05:09 PM
water run off in shed kathy k Building & Construction 4 08-09-2009 03:29 PM
Hot water won't stop running rickp47 Plumbing 8 02-19-2009 04:33 PM
Water Softener wont stop draining help TTran Plumbing 3 08-24-2008 08:16 PM
