Old 12-02-2011, 10:20 PM   #1
how do I seal cracks in concrete stairs and patch a hole?
What type of cement should I use to patch this hole? Do you think if I screwed some of those blue cement anchor screws into it that it would hold the patch better? Should I support the patch with a piece of plywood and a cinder block?
Also, what can I put on these fine cracks to keep water out so that it doesn't freeze and turn into a bigger crack?
Thank you!
how do I seal cracks in concrete stairs and patch a hole?-img_3893.jpg   how do I seal cracks in concrete stairs and patch a hole?-img_3751.jpg
h82diet is offline   Reply With Quote
Extension on Outside Concrete stairs i8kermit Building & Construction 1 07-28-2010 07:11 PM
Concrete chunk fell off of entrance stairs curls00 General Discussion 20 05-18-2008 07:54 PM
