How Do I Replace Damaged Siding In The Middle Of The Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 11:06 PM   #1
Rewards Points: 91
How do I replace damaged siding in the middle of the wall?
I think I can do it and it should not be too hard.
The siding has a couple holes in the middle of the wall. I figure to remove old pieces of siding and cut new ones to length.
In order to put new pieces up so that they are firmly in place I plan to mark a line along the top edge of the old piece before I remove it. Then I will position the new piece on the line and nail in place.
To get the old pieces, that are above the new pieces, to lock in place, is it adequete to just tug on the edge by hand and snap it over the top of the new piece. Or is it required that I buy one of those tools for that purpose?
Is my plan good or is there a better way?
Thanks.
sofasurfer is offline   Reply With Quote
Old 07-07-2011, 12:43 AM   #2
AGWhitehouse's Avatar
Are you talking vinyl, wood, hardiplank, etc?
If it is vinyl, then just snap the pieces out, cut lengths to match, and reinstall leaving the nails loose as you should see when you remove the panels.
To snap them out and back in, use a hooked tool (the right ones are pretty cheap at most Home improvement stores) under the bottom edge of a siding piece. You can find the bottom of a piece by checking at one of the vertical seams.
AGWhitehouse is offline   Reply With Quote
Old 07-07-2011, 01:26 AM   #3
Rewards Points: 91
It is vinyle. What is the best way to cut it...just a box cutter?
Old 07-07-2011, 08:27 AM   #4
joed's Avatar
Rewards Points: 12,024
Use what is called a zipper tool to release the lock on the bottom and put the final one back on.
Cut it with tin snips.
A zipper tool
Old 07-07-2011, 08:28 AM   #5
kwikfishron's Avatar
Rewards Points: 218
Tin snips.
kwikfishron is online now   Reply With Quote
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
OSB Panel Siding: Repair or Replace SirDieAlot Building & Construction 5 06-03-2008 09:19 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
