Old 06-04-2010, 04:43 AM   #1
How do I remove sliding glass doors?
I searched and couldn't find the answer to this. I'm finishing a basement and went to bring the shower enclosure through the door and - whoops - won't fit. Yeh, I know - measure first
I know that the height can be adjusted from screws on the ends of the doors and that the doors should "lift" out but. . . I can't figure out the adjustment method and the doors won't lift high enough to come out of the track - it's very close, just no cigar.
I can't find any manufacturers information and the only clue I can give is that there are two screws at the bottom end of the doors - a small silver one over top of a larger gold one?
Any ideas on how to get them out?
Thanks,
Rick
upinsmoke is offline   Reply With Quote
Old 06-04-2010, 06:12 AM   #2
Super Moderator
On Anderson--any many other brands --the moving door is kept in place by a strip of wood or plastic at the top of the frame,on the inside.
Look up and see if there is a row of screws on the top near the trim.
Post a picture--that will help.--Mike--
Old 06-04-2010, 06:51 AM   #3
Totally screwed together
You might need to turn the screws to lower them enough so it will tilt out.
xxPaulCPxx is offline   Reply With Quote
The Following User Says Thank You to xxPaulCPxx For This Useful Post:
oh'mike (06-04-2010)
Old 06-04-2010, 07:16 AM   #4
Mod
kwikfishron's Avatar
Yep, some of those doors can be stubborn to get out. As Mike said there might be a trim strip at the top. If so you will see either screws or the plugs covering them. If not what I do is take a thin piece of metal, usually a scrap of flashing but I suppose a thin putty knife would work and as someone is lifting the door use the metal to slide under the roller. It should then just pop out.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 06-05-2010, 05:41 AM   #5
Thanks - as it turns out kwikfish was right. I took out every screw I could find and the damn door still wouldn't come out. My framers showed up and gave me a hand.
One of them lifted the door - the other pried the wheel up one at a time and was able to get the door out. Then, while out, I lubed them (lightly) and made sure the wheels were screwed all the way into the retracted position and although it went back in - it was really close.
Thanks for the help.
The Following User Says Thank You to upinsmoke For This Useful Post:
oh'mike (06-05-2010)
Who to call for sliding glass door repair Jane1976 Off Topic 2 05-18-2010 08:40 AM
Sliding Glass Door: Inserts or Replace? roztom Carpentry 6 07-20-2008 04:53 PM
8' Glass Sliding Doors dankreboot General Discussion 6 07-10-2008 09:11 AM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 01:43 AM
Help!! Removing sliding doors? luo2000 General Discussion 11 04-10-2006 12:10 PM
