How Do I Remove This Rebar? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 11:22 AM   #1
"You can do anything"-Mom
brockmiera's Avatar
How do I remove this Rebar?
I tried banging it, pulling it, and asking it nicely to leave. Nothing has worked so far.
How do I remove this Rebar?-shower-drain.jpg   How do I remove this Rebar?-2012-10-17-19.24.18.jpg
brockmiera is offline   Reply With Quote
Old 02-06-2013, 11:37 AM   #2
joed's Avatar
Rewards Points: 12,924
Not sure what the second picture is but the in the first picture I would just get an angle grinder and cut off the 6 or so rebars that are sticking up.
The Following 2 Users Say Thank You to joed For This Useful Post:
gregzoll (02-06-2013), woodworkbykirk (02-06-2013)
Old 02-06-2013, 11:44 AM   #3
Rewards Points: 2,516
I think the right picture is the before picture and the left picture is the after picture.
hammerlane is offline   Reply With Quote
Old 02-06-2013, 11:48 AM   #4
brockmiera's Avatar
That is true. The pictures went in the wrong order. Bottom picture is the concrete curb that has been blasted out with a hammer. The top picture is the rebar that remains.
Angle grinder you say? What kind of blade?
Old 02-06-2013, 11:56 AM   #5
MarginallyQualified
Rewards Points: 2,464
Ones meant for metal.
Thinner blades will give a neater cut.
Thicker blades will allow you to grind on what remains.
You'll need both.
Old 02-06-2013, 01:48 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
yup. standard zip wheels
woodworkbykirk is offline   Reply With Quote
Old 02-06-2013, 04:16 PM   #7
joed's Avatar
A sawzall with a metal blade will do it also. Might to grind a small bit down level with the angle grinder after the cut.
Old 02-06-2013, 04:53 PM   #8
brockmiera's Avatar
Ok I can try that. I actually have a metal blade for my sawzall. I hope it works but if it doesn't I guess I'll have to go buy a new angle grinder!
The Following User Says Thank You to brockmiera For This Useful Post:
BigJim (02-06-2013)
Old 02-06-2013, 06:31 PM   #9
recip blades work but they burn up pretty quick. if you have a grinder zip wheel its faster and more economical
Old 02-06-2013, 06:42 PM   #10
Roofmaster
Rewards Points: 2,210
Yup right angle grinder with thin reinforced metal blades. You can also use an offset adapter in your sawsall, and a long hack blade, you just flex the blade down into a curve so it runs along the floor.
Old 02-06-2013, 08:14 PM   #11
by doing that the teeth will dull even quicker from the action of having the blade rubbing on the concrete. hence angle grinder being a better idea
Old 02-06-2013, 08:40 PM   #12
kwikfishron's Avatar
Rewards Points: 618
One Sawzall blade will easily cut what you show in the picture.
An angle grinder will zip them off just fine too but I have a hard time recommending a grinder first when other (safer) methods will work just fine, especially here, in a DIY Forum.
kwikfishron is offline   Reply With Quote
Old 02-06-2013, 08:41 PM   #13
Rewards Points: 6,652
Also a buddy or gal friend with a Oxy-Acetylene torch works also.
Old 02-11-2013, 02:45 PM   #14
brockmiera's Avatar
Well a new 4.5" angle grinder was the winner. Once thin metal blade a poop load of sparks. It worked like a charm.
Old 02-11-2013, 03:36 PM   #15
GBrackins's Avatar
Rewards Points: 2,108
that's sweet Brock!
my ex finally gave up giving me a "Honey-Do List" when she realized that meant some new tools for Daddy ......
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Size Rebar Needed to Reinforce Bowed Block Wall frtools Concrete, Stone & Masonry 7 06-18-2012 11:28 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 10:48 AM
Rebar for Monolithic Slabs portert0224 Building & Construction 1 07-03-2008 11:37 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 02:10 AM
