#16 |
Moderator
How do I reinforce compromised load-bearing studs?
If the doorway wall has a header in it and is carrying the load from ceiling/floor above, there is probably a king stud and jack stud still supporting it. (Under the trim casing). The 3 studs are carrying a point load from above OR are just backing for the doorway (partition) drywall. It may just be blocking sandwiched between two studs if not loaded and you drilled through the solid blocking.
Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | mae-ling (02-26-2012) |
| Tags |
holes, load-bearing, reinforce, studs, wall ![]() |
| Display Modes | |
| Do you think this wall is load bearing? | rchickering | Remodeling | 17 | 11-21-2011 06:35 PM |
| Determining a Load Bearing Wall (Pic Included) | Evil Scotsman | General Discussion | 18 | 03-02-2011 03:46 PM |
| Load Bearing wall or not? | Dennis6950 | Remodeling | 5 | 02-01-2011 09:34 PM |
| load bearing walls | rvesci | General Discussion | 4 | 12-28-2010 10:51 PM |
| Load bearing wall! | Newtsjetson | Building & Construction | 2 | 12-19-2010 08:46 AM |
