How Do I Reinforce Compromised Load-bearing Studs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 08:20 AM   #1
rsclement's Avatar
Question
How do I reinforce compromised load-bearing studs?
Here is the issue. Due to lack of knowledge, a hole 2 1/2" in diameter was drilled through what I now know to be load-bearing. It is in the doorway to the living room from the foyer and there are 3 studs together. Should I remove the drywall on either side of the doorway and attach a full lenght stud with glue and nails to each to reinforce? Any other options like steel plates etc.
This is on the main floor. There is a basement and an upstairs. Was originally drilling to run wires for to allow home theatre equipment to be placed in a closet.
Need some advice. Thanks in advance!
rsclement is offline   Reply With Quote
Old 02-21-2012, 08:29 AM   #2
Rewards Points: 13,276
Why 2-1/2? Could have been done with a much smaller hole.
The sheetrock only needs to be removed on one side. Just set new studs next to the ones already and nail at the top and bottom. No need to nail them together in the middle.
Old 02-21-2012, 08:34 AM   #3
rsclement's Avatar
Good question. Just didn't know. Going to run several wires. (4 hdmi, 1 cat6...). I appreciate your help and quick response!
The Following User Says Thank You to rsclement For This Useful Post:
jcrack_corn (07-30-2014)
Old 02-21-2012, 09:06 AM   #4
Civil Engineer
Rewards Points: 4,566
Based on your description, it sounds like you may have drilled clear through three studs back to back. These may have been two trimmer studs and one king stud supporting a header. You need to check this possibility out, because if that is what you did, your header on one side has been severely compromised, and adding one stud is not likely to be adequate.
Daniel Holzman is online now   Reply With Quote
Old 02-21-2012, 10:23 AM   #5
Rewards Points: 626
look at this link it is more help full then here some times.
http://www.familyhandyman.com/DIY-Pr...-in-wood-studs
FYI 3 1/4 " hole max for a 2x6 stud. An 2 1/8th max. for a 2x4 stud
Nailbags is offline   Reply With Quote
Old 02-22-2012, 06:23 PM   #6
rsclement's Avatar
Thanks. Sounds like I have my work cut out for me.
Old 02-22-2012, 06:37 PM   #7
Rewards Points: 81
Could a stud shoe provide adequate reinforcement?
JeepNick is offline   Reply With Quote
Old 02-22-2012, 07:31 PM   #8
Rewards Points: 2,210
May have to Remove drywall on one side, Temporary support header, remove drilled studs, install new studs, remove temp support, redrywall.
mae-ling is offline   Reply With Quote
Old 02-22-2012, 11:01 PM   #9
Rewards Points: 626
If the studs are 2x6 he can drill a 3&1/4 inch hole and be ok.
Old 02-23-2012, 12:08 AM   #10
Registered User
Rewards Points: 5,216
2X4 wall?
Width of doorway?
Load above doorway?
Location?
R602.6 Drilling and notching-studs. Drilling and notching of studs shall be in accordance with the following:
1. Notching. Any stud in an exterior wall or bearing partition may be cut or notched to a depth not exceeding 25 percent of its width. Studs in nonbearing partitions may be notched to a depth not to exceed 40 percent of a single stud width. 2. Drilling. Any stud may be bored or drilled, provided that the diameter of the resulting hole is no more than 60 percent of the stud width, the edge of the hole is no more than 5/8 inch (16 mm) to the edge of the stud, and the hole is not located in the same section as a cut or notch. Studs located in exterior walls or bearing partitions drilled over 40 percent and up to 60 percent shall also be doubled with no more than two successive doubled studs bored. See Figures R602.6(1) and R602.6(2).
Exception:
Use of approved stud shoes is permitted when they are installed in accordance with the manufacturer's recommendations.
For SI: 1 inch = 25.4 mm.
NOTE:
Condition for exterior and bearing walls.
FIGURE R602.6(1) NOTCHING AND BORED HOLE LIMITATIONS FOR EXTERIOR WALLS AND BEARING WALLS
If under the IRC: http://publicecodes.citation.com/ico...002_par012.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
mae-ling (02-23-2012)
Old 02-23-2012, 07:18 AM   #11
rsclement's Avatar
Here are some photos. I will get measurements shortly. Big question is how to fix it. What to brace. What to cut. What to replace. There is another story /floor above. Thanks for help.
How do I reinforce compromised load-bearing studs?-image-351556222.jpg   How do I reinforce compromised load-bearing studs?-image-1387307337.jpg   How do I reinforce compromised load-bearing studs?-image-4024416115.jpg   How do I reinforce compromised load-bearing studs?-image-3208336608.jpg
Old 02-23-2012, 01:07 PM   #12
Rewards Points: 626
Well Did you do the notching? If not I would be going after the contractor.
a 3/4 hole would have been enough for cat 5 and coax. you need to replace all them studs they so take off the sheetrock brace up the top plate use a saws all with a thin blade to carefully cut out one stud then put the new one in. then repeat till done.
Old 02-23-2012, 02:40 PM   #13
Yep as Nailbags said, or ou could sister new studs beside old ones. Where it goes behind the intersecting wall put one on both sides maybe. Typically the header above the door should be supported by studs in the wall it is on and it does not look like you touched them, or did you?
Old 02-24-2012, 09:33 AM   #14
rsclement's Avatar
I believe I did. Looks like 3 studs together. Should I place a jack under doorway prior to working on it?
Old 02-24-2012, 11:18 AM   #15
Rewards Points: 150
Have you determined whether the wall with the opening is load bearing or not?
Regardless, those 3 studs are there for a reason. Possibly to take some roof loading. They should be replaced in full, but you will need a an excellent understand of the structure for any temporary support you will require.
psilva8 is offline   Reply With Quote
Tags
holes , load-bearing , reinforce , studs , wall
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 06:35 PM
Determining a Load Bearing Wall (Pic Included) Evil Scotsman General DIY Discussions 18 03-02-2011 03:46 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 09:34 PM
load bearing walls rvesci General DIY Discussions 4 12-28-2010 10:51 PM
Load bearing wall! Newtsjetson Building & Construction 2 12-19-2010 08:46 AM
