Old 11-30-2006, 05:03 PM   #1
how do i put a frame on uneven drywall
I put a attic ladder up but the drywall around the attic door is not even with the frame. Some of it is even but some is not. How do I put a frame around the opening with uneven drywall?
jerry1967 is offline   Reply With Quote
Old 11-30-2006, 08:29 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Can you please be more specific...about what you actually mean by "not even with the frame"?
Thanks,
-C
- Build Well -
Old 11-30-2006, 08:36 PM   #3
remodeling pro
Sounds like you need to remove the screws in the frame and adjust until flush with the ceiling.Easier with two people..one in the attic and one below to gauge the correct position of the frame. If all four corners are flush, then the ceiling must be wavy. Use the door frame as a screed for a drywall knife, and float the ceiling flat. Or shim as needed to hold the moulding in place, caulk the gaps, and live with it.
troubleseeker is offline   Reply With Quote
Old 12-01-2006, 08:43 AM   #4
Is this drywall or plaster and lath?
How much is it off?
redline is offline   Reply With Quote
Old 12-02-2006, 03:38 PM   #5
How much is it off?
It is drywall and it is off about 1/2 inch.
drywall onto uneven walls? johnny331 Remodeling 5 06-28-2007 08:59 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
putting a frame on uneven drywall jerry1967 Carpentry 7 12-03-2006 06:02 PM
Drywall to stone transition IraF16 Carpentry 1 03-17-2006 03:02 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
