How Do I Measure A Brick Pillar. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 04:48 AM   #1
How do I measure a brick pillar.
Hi,
I've been asked to measure a 350mm x 350mm by 1050mm brick gate post, I'm trying to work out the M2 but I'm going round in circles.
Would it be best to measure one side i.e 350mm x 1050mm and then multiply by the 4 sides to get the answer.
so 0.35m x 1.05m = 0.36 then 0.36 x 4 = 1.47m2?
Is this the right way to do it?
Issi is offline   Reply With Quote
Old 01-21-2012, 05:53 AM   #2
Retired carpenter
0.35 m x 0.35 m x 1.05 m define a volume, not an area. Are you sure you are not supposed to find the cubic meters?
Just multiply length x width x height: 0.35 m x 0.35 m x 1.05 m = 0.123 cubic meters.
abracaboom is offline   Reply With Quote
The Following User Says Thank You to abracaboom For This Useful Post:
Issi (01-21-2012)
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 09:09 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 10:41 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 04:04 PM
