How Do I Make A Wall Straight, - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-09-2007, 09:51 PM   #1
how do i make a wall straight,and square.
hi all and thanks for any help you may have,
we had some water damage which led to me removing the plaster and lath from the walls and ceiling. then proceeded to shim the studs to make them as straight and level as poss,which is not fun in a 100 yr house,.LT hen i came to an (in corner and an out corner )sorry for the poor description,anyway i cannot figure how to make both corners square, as a level seams to play no part in helping me know if the studs side by side are straight with each other? ________________
_|.... < in corners>....|_B
| ............................ | < out corner
| ............................ |A
|___________________|
the wall A is not straight and the corner B is not square. i need a starting point.
Last edited by always something; 03-17-2007 at 09:01 AM. Reason: beter description
always something is offline   Reply With Quote
Old 03-09-2007, 11:26 PM   #2
Rewards Points: 1,232
You lost me on the description, but levels are used to level and plumb, while stinglines and lasers are used to assure straight lines, and framing squares are used to assure 90 degree corners.
Tscarborough is offline   Reply With Quote
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
cannot make cabinets flush with wall barcoo Carpentry 3 07-20-2006 11:58 PM
