Old 09-29-2012, 11:07 AM   #16
AHH, SPANS!!!
How do I jack to replace floor beam on piers in a cottage.
consider making it a basement by adding skirting to the underside of the house to protect the underside from the outside, might be worth considering. Then the only moisture would be from the ground in the basement and you could put down plastic to keep the moisture contained...
hand drive is offline   Reply With Quote
Old 09-29-2012, 06:01 PM   #17
Thanks Hand Drive.Sounds like a good idea!
SteveValeriotte is offline   Reply With Quote
Tags
beam, foundation, piers, rotted, sister
How to replace a rotten sill plate, joists, and subflooring. jtalley Building & Construction 19 10-24-2012 02:43 PM
How to replace porch footings? Joeychgo Building & Construction 11 08-06-2012 01:05 PM
Need to replace jack post, do I need to replace footing pad, please read... rosco4069 Building & Construction 1 10-03-2011 07:26 AM
Phone/Fax Wall Jack cmgith Electrical 5 04-19-2009 12:21 AM
Can I use Microlam for Jack Studs? (Enlarging Door Opening) Kevin8565 Carpentry 7 04-30-2008 01:27 PM
