How Do I Insulate This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2009, 11:27 AM   #1
I have taken out old insulation, vapor barrier and sheetrock in an area of my basement where I had some moisture issues this fall (small sump pump failure, some walls were damp when I pulled away old insulation, some insulation was a little wet). I have let the area dry really well, bleack cleaned the walls and now I am ready to start in with the project. The walls are framed out as shown in the picture below. My questions are:
1. Vapor Barrier? There was previously a vapor barrier on the warm side of the insulation between the insulation and the sheetrock. DO I stick with this: brick basement wall-insulation-vaporbarrier-sheetrock? Or go to...brick basement wall-vapor barrier - insulation - sheetrock? I am not sure on the exterior of the foundation in terms of other insulation. Can I use 6 mil poly for the barrier or should i move to rigid foam insulation? If rigid foam, then how to I retro fit based on the fact that my basement is already framed out?
2. The second picture shows you a space between the foundation and joist ends. The previous owner stuffed some hand filler insulation up there. It appears to have gotten wet over the years (brown/black marks and graying). Is ther a better way to insulate this area? I thought about 3 inch rigid pin isulation, foamboard caulk and great stuff. Any other ideas based on the picture?
3. Dry Lok? Should I use a masonary paint such as dry lok to help wioth the vapor barrier issue and potential moisture issue?
livinginthepark is offline   Reply With Quote
Old 01-06-2009, 09:18 AM   #2
Anyone have any ideas about whether or not to use a vapor barrier on this project?
Old 01-06-2009, 09:39 AM   #3
Are your studs placed up against the wall or is there a proper airspace behind them?
Rivethead is offline   Reply With Quote
Old 01-06-2009, 09:54 AM   #4
Rivethead - There is about a 1-2" gap between the framing and the brick wall. Any suggestions?
Old 01-06-2009, 06:55 PM   #5
The insulation at the top of the wall just looks dusty to me from air filtration. Pull some of it out and see if it's damp. If you replace it - don't pack it in too tightly or you lose your insulation effectiveness. (why don't we see a sill plate in your photo of that area?) I wouldn't try great stuff - you really have to use that product with care due to over expansion.
Is the wall is showing you that it has a current moisture issue. Any good rains since you took the wall down. If it's not staying damp I'd do drylok oil based or the drylok "extreme" latex. Insulate with kraft faced fiberglass and hang my drywall. Make sure the insulation depth allows for a clear airspace behind the wall.
Make sure your gutters are clean and the ground is properly sloped away from the house.
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
Framing in basement attached to concrete blocks, how to insulate? drnormie Remodeling 11 01-21-2009 06:40 PM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 07:07 PM
Best way to insulate around a breaker box? Chip718 Building & Construction 5 11-15-2006 10:28 PM
