How Do I Insulate THIS?!?! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2008, 07:07 PM   #1
Token Canadian
How do I insulate THIS?!?!
Hey guys. I was insulating my headers in the basement, and I have gotten about 85% done. It is MUCH easier than I thought it would be..... Until now..
The spots where I had 15" centers were no problem. (North and South sides of the house) Cut and Stuff. However, the East and West side of the house seem to be a bit harder. Since the joists run North/South, I have no issue there. However, how do I go about insulating the flat joists that are running the length of the East/West side of the basement?? There are no easy 15" centers there!
Here is a pic: (It was too large, so I hosted it.. 56K - NO!)
http://www.londongolfers.com/forums/...insulation.jpg
Do you see the top right of that picture? That is the East Wall. The long piece of wood running at the top right is the joist. For some reason, the people that owned the house prior to my wife and myself made a false wall that gives me that 16" space you see there. They stuffed the inside of the false wall with some sort of insulation pictured in the left of that pic.
I would ASSume the quick and dirty way here is to expandable foam the living hell out of that crack at the bottom of the joist?
Any help here is appreciated, guys!
(IT may be placebo, however I think I notice a large difference in the temperature of the basement already with only 85% done! That last 15 feet is the only thing I have left! Then the vapor barrier work begins.
Thanks again!
Matt
M_Portiss is offline   Reply With Quote
Old 02-06-2008, 09:14 PM   #2
Easy. Cut long pieces of R10 pink foamboard to fit there. Nail in place with washer headed nails. Foam the long crack closed and then foam all around the nailed in foamboard including any seams. Btw, that insulation in the false wall isnt doing a thing for insulating but you knew that.
jaw22 is offline   Reply With Quote
Old 02-06-2008, 09:27 PM   #3
Token Canadian
Fair enough. Thanks! Should I worry about insulating the actual foundation, or should I only worry about above the front line?
Actually, I had no idea that the existing stuff was worthless. Thanks for that. Now I can take it and use it in other places!
Should I insulate an attached garage? pbkid Building & Construction 11 07-09-2011 03:31 PM
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
How to insulate under a shed floor 6n165 Building & Construction 3 01-04-2008 12:55 PM
Best way to insulate around a breaker box? Chip718 Building & Construction 5 11-15-2006 10:28 PM
