How Do I Install This Stacked Trim? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 06:21 PM   #1
Rewards Points: 508
How would I achieve the stacked trim in this picture?
Also, is that a full eave return on the gable end?
*Edit* Any reccomendations on a comprehensive and well-illustrated book on exterior trim would be welcome.
How Do I Install This Stacked Trim?-ma-20greek-20revival-20exterior-resized-600-2-.jpg
benjamincall is offline   Reply With Quote
Old 05-25-2011, 06:33 PM   #2
Framing Contractor
Rewards Points: 100
You would install the lower trim first, then attach the upper trim with it slightly covering the edge of the lower. You may need to pack out above the lower trim to give you a solid backing for the upper. 3/4 plywood will probably do the trick for the packing.
sixeightten is online now   Reply With Quote
Old 05-25-2011, 11:33 PM   #3
Rewards Points: 508
Rain screen
I imagine the bottom layer of trim on the stacked frieze should also rest on a layer of plywood (7.14 below) since shim strip seems like it would really difficult given the angle of the frieze board on the gable end.
Do I also need to keep the top of the rain screen open somehow?
(Image from the Hardie Trim installation manual)
Old 05-26-2011, 08:04 AM   #4
Framing Contractor
Rewards Points: 100
The freeze board does not have to go over the siding. In my experience, it is more common to see the siding butted into the freeze.
Old 05-26-2011, 09:29 PM   #5
Rewards Points: 508
Rainscreen
The furring strips will provide a gap of approximately 1/4" behind the siding. I think I'm going to use blocking (the "shim strip" in the drawing above) under the frieze board of a dimension such that it will sit slightly higher than the siding. I'm going to cut the the siding slightly short of this blocking to allow air to circulate properly. I saw an interesting article on the topic in Fine Homebuilding.
Old 05-26-2011, 09:48 PM   #6
kwikfishron's Avatar
Rewards Points: 92
I’d dado the bottom of the frieze board ( 1”+) and lap that over the siding so it sheds water, just like all of the siding pieces below it.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
tpolk (05-28-2011)
Old 05-27-2011, 12:36 AM   #7
Rewards Points: 508
Originally Posted by kwikfishron View Post
Id dado the bottom of the frieze board ( 1+) and lap that over the siding so it sheds water, just like all of the siding pieces below it.
Yeah, I like the idea of rabbeting the frieze board. I think the gap to vent the rainscreen might be a lot less obvious if I could overlap where the frieze and the siding meet. Does such thing as a fiber cement dado blade exist? I was planning on using Hardie Trim.
Old 05-27-2011, 08:21 AM   #8
Framing Contractor
Rewards Points: 100
You will probably not like the hardi trim. The siding is nice, but the trim is very difficult to work with and ends up not looking very crisp. We generally use Azek for the trim on Hardi siding jobs. Azek is very nice to work with and can be cut using standard wood blades.
Old 05-27-2011, 09:20 AM   #9
Rewards Points: 508
I was avoiding Azek because people seem to have gaps open up with the expansion and contraction of the product.
Old 05-27-2011, 10:17 AM   #10
Framing Contractor
Rewards Points: 100
There are some concerns with that. There are also some better methods to the install. Pocket screws, biscuits, and slip joints have all proved effective. I urge you to find a job that used the Hardi trim and inspect it closely. The long edges come from the factory very rough and sometimes irregular. It is very brittle, difficult to nail, and cutting it accurately is akin to cutting a concrete slab.
The Following User Says Thank You to sixeightten For This Useful Post:
benjamincall (05-27-2011)
Old 05-28-2011, 05:18 AM   #11
Rewards Points: 508
On a side note, how often do you use a 6" corner board?
Old 05-28-2011, 07:28 AM   #12
Framing Contractor
Rewards Points: 100
6" corners are very common here.
Old 05-28-2011, 10:44 AM   #13
KemoSabe
loneframer's Avatar
I love the look of that house.
That can be pulled off with PVC trim, however, expansion and contraction will be a concern. No amount of nails or glue/cement will prevent it either.
I've done tons of Azek work and in my experience, glued joints will hold for a year, sometimes two, but in my area, we have large temp swings through the seasons and eventually something will give and gaps will open up.
Miratec makes a good product, but I think it is prone to some movement as well and I'm not sure there are many profile options.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 05-28-2011, 04:54 PM   #14
Rewards Points: 92
Does anybody remember wood?
Believe it or not it still works good, always has. If it's going to paint 2x finger jointed primed Cedar is my trim of choice. Looks Great. Doesn’t have to be white. No expansion/contraction issues.
After the LP thing everyone thinks the world should be wrapped in plastic or cement. I disagree.
Spending all that money on “maintenance free” and “forever” guess what, they don’t exist.
If the trend continues grandmas plastic couch covers will be back.
Put whatever you want on your house but I vote wood.
Old 05-29-2011, 02:18 AM   #15
Rewards Points: 508
How about a compromise?: Miratec.
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 7 09-05-2013 07:00 PM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 05:01 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 02:31 PM
