-   -   How Do I Install This Stacked Trim? (http://www.diychatroom.com/f19/how-do-i-install-stacked-trim-105576/)
benjamincall 05-25-2011 06:21 PM
1 Attachment(s)
How would I achieve the stacked trim in this picture?
Also, is that a full eave return on the gable end?
*Edit* Any reccomendations on a comprehensive and well-illustrated book on exterior trim would be welcome.
sixeightten 05-25-2011 06:33 PM
You would install the lower trim first, then attach the upper trim with it slightly covering the edge of the lower. You may need to pack out above the lower trim to give you a solid backing for the upper. 3/4 plywood will probably do the trick for the packing.
benjamincall 05-25-2011 11:33 PM
Rain screen
1 Attachment(s)
I imagine the bottom layer of trim on the stacked frieze should also rest on a layer of plywood (7.14 below) since shim strip seems like it would really difficult given the angle of the frieze board on the gable end.
Do I also need to keep the top of the rain screen open somehow?
(Image from the Hardie Trim installation manual)
sixeightten 05-26-2011 08:04 AM
The freeze board does not have to go over the siding. In my experience, it is more common to see the siding butted into the freeze.
benjamincall 05-26-2011 09:29 PM
Rainscreen
The furring strips will provide a gap of approximately 1/4" behind the siding. I think I'm going to use blocking (the "shim strip" in the drawing above) under the frieze board of a dimension such that it will sit slightly higher than the siding. I'm going to cut the the siding slightly short of this blocking to allow air to circulate properly. I saw an interesting article on the topic in Fine Homebuilding.
kwikfishron 05-26-2011 09:48 PM
199 Attachment(s)
I’d dado the bottom of the frieze board ( 1”+) and lap that over the siding so it sheds water, just like all of the siding pieces below it.
benjamincall 05-27-2011 12:36 AM
Originally Posted by kwikfishron (Post 655789)
Id dado the bottom of the frieze board ( 1+) and lap that over the siding so it sheds water, just like all of the siding pieces below it.
Yeah, I like the idea of rabbeting the frieze board. I think the gap to vent the rainscreen might be a lot less obvious if I could overlap where the frieze and the siding meet. Does such thing as a fiber cement dado blade exist? I was planning on using Hardie Trim.
sixeightten 05-27-2011 08:21 AM
You will probably not like the hardi trim. The siding is nice, but the trim is very difficult to work with and ends up not looking very crisp. We generally use Azek for the trim on Hardi siding jobs. Azek is very nice to work with and can be cut using standard wood blades.
benjamincall 05-27-2011 09:20 AM
I was avoiding Azek because people seem to have gaps open up with the expansion and contraction of the product.
sixeightten 05-27-2011 10:17 AM
There are some concerns with that. There are also some better methods to the install. Pocket screws, biscuits, and slip joints have all proved effective. I urge you to find a job that used the Hardi trim and inspect it closely. The long edges come from the factory very rough and sometimes irregular. It is very brittle, difficult to nail, and cutting it accurately is akin to cutting a concrete slab.
benjamincall 05-28-2011 05:18 AM
On a side note, how often do you use a 6" corner board?
sixeightten 05-28-2011 07:28 AM
6" corners are very common here.
loneframer 05-28-2011 10:44 AM
I love the look of that house.
That can be pulled off with PVC trim, however, expansion and contraction will be a concern. No amount of nails or glue/cement will prevent it either.
I've done tons of Azek work and in my experience, glued joints will hold for a year, sometimes two, but in my area, we have large temp swings through the seasons and eventually something will give and gaps will open up.
Miratec makes a good product, but I think it is prone to some movement as well and I'm not sure there are many profile options.
kwikfishron 05-28-2011 04:54 PM
199 Attachment(s)
Does anybody remember wood?:thumbup:
Believe it or not it still works good, always has. If it's going to paint 2x finger jointed primed Cedar is my trim of choice. Looks Great. Doesn’t have to be white. No expansion/contraction issues.
After the LP thing everyone thinks the world should be wrapped in plastic or cement. I disagree.
Spending all that money on “maintenance free” and “forever” guess what, they don’t exist.:no:
If the trend continues grandmas plastic couch covers will be back.:eek:
Put whatever you want on your house but I vote wood.:thumbsup:
benjamincall 05-29-2011 02:18 AM
How about a compromise?: Miratec.
