How Do I Get This Swing Set Out Of The Ground? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 12:01 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
How do I get this swing set out of the ground?
I have a swing set that is set into the ground with cement.
I don't thing there is a lot of cement in each post.
What is the best way to do it.
I want to do it the easy way and just cut the darn legs but then I have these 6 tubes in the dirt and grass.
yummy mummy is offline   Reply With Quote
Old 05-27-2011, 01:47 AM   #2
Maryland
Cut the posts and break up the concrete. Depending on the thickness, you may want to rent a jackhammer. After it's all removed, fill the holes with soil and plant grass seed.
Pittsville is offline   Reply With Quote
Old 05-27-2011, 07:07 AM   #3
Rewards Points: 5,336
Cut the posts off about 4 feet above the ground. Try pushing the post back and forth to loosen the concrete/ dirt connection. If it gets loose enough, lift it out of the ground. If not, dig around the concrete until it is.
They sell a mechanism that you can attach to the post and lift it out of the ground. It's used with fence posts. Maybe someone has a link.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
DangerMouse (05-27-2011)
Old 05-27-2011, 08:27 AM   #4
Thanks everyone for your help.
Ron, what a great idea! I am going to do that, and I hope I can dislodge it somehow.
Thanks again.
Old 05-27-2011, 08:44 AM   #5
Old School
Willie T's Avatar
Keep in mind that if you use a mechanical extractor, the base needs to be positioned far enough from the pipe so that it is not located above the plug of concrete in the ground. Othewise you will crank away all day long, and accomplish nothing. Sort of like trying to climb a ladder that is sitting on top of one of your feet.
Willie T
Old 05-27-2011, 08:50 AM   #6
Learning by Doing
Leah Frances's Avatar
Here's what I have done. It's messy, but for one person working alone, it is a low effort method. Especially when you have six of these to remove.
1) Drill a hole through the tube low and close to the concrete. Put a long eye bolt through it and throw on a couple nuts. (this is in case it is really heavy and you need to chain it to something to pull it out)
2) Cut the tube high enough above the eyebolt to give a good "handle". A foot or more.
3) Here's the messy part Put a nozzle on the end of your hose. Put the nozzle on the ground right between the tube of concrete and the grass. Turn it on full blast and push it down as it liquifies the dirt. Go down a ways and repeat around the circumference of the tube N-S-E-W. Use the handle and see if it's getting loose. Repeat as necessary.
4) once it starts getting loose use the handle as a lever to get it out; or toss some tow rope and pull it out with a car/truck.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-27-2011, 08:55 AM   #7
Thanks Leah! That is a great idea to loosen the dirt.
Old 05-27-2011, 08:56 AM   #8
Sounds like something I probably would get myself into.....
Hopefully, I can do it by hand without a mechanical extractor.
Old 05-27-2011, 02:45 PM   #9
If you want to be able to sell, give away or reuse the swing set, you could try to use an automotive cherry picker (hydraulic lift), use some chains, position a 1 inch board in the ground for the lift base, and then hook up the chains and lift it out of the ground. You could also use some hydraulic floor jacks and a 4x4 under the center tubes and lift it out that way too. But if you just want it gone to junk it, then cut the tubes first and then go one by one with a jack and chains. Before you do any digging around the area, make sure theres no utilities, better yet, call diggers hotline to have them mark the area to be sure theres no utilities.
Wiscbldr is offline   Reply With Quote
Old 05-27-2011, 08:15 PM   #10
Rewards Points: 266
i would list it on craigslist as FREE for Hauling and state they must fill the holes.
it will be gone and someone will have a swingset to use
What have I done is offline   Reply With Quote
Old 05-27-2011, 08:27 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Do you want to salvage this swing set?
Remove the top rail and turn the yard sprinkler on so that the four posts are watered. Soak the ground. With the four posts separated from one-another and independent of the top rail you should be able to rock and loosen each post individually. Bet they aren't very deep in the ground. Once the posts are out, a sledge hammer will break-away the concrete with a little effort. Throw the broken concrete back into the holes and fill with dirt after that.
XXX
Old 05-27-2011, 09:44 PM   #12
Thanks everyone for your help. The swing set is rather old and I am going to get rid of it.
I will try soaking the ground and dislodging it.
Sledge hammer, here I come......lol
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 12:14 PM
