How Do I Fix My Front Porch Wood Columns, That Are Rotting Along The Bottom? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 12:57 PM   #1
How do I fix my front porch wood columns, that are rotting along the bottom?
The bottom edges of our front square pillars are starting to rot. Is there a way I can repair them, instead of replacing them?
Kelli.Blazevich is offline   Reply With Quote
Old 03-03-2012, 01:04 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
not really no unles you jack up the porch temporarily to take the weight.. cut the posts off and build a larger base for them to bear on...
woodworkbykirk is online now   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
jaydevries (03-03-2012), mae-ling (03-03-2012)
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
mounting 4x4 wood post to concrete porch pshinaults Building & Construction 1 05-27-2010 03:53 PM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 01:29 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 09:06 PM
