How Do I Fix This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 07:07 PM   #1
how do i fix this?
I have a spot in my living room where the room juts out a little and there is no soil under neath it. The carpet in that area of the room is about 10 degrees cooler than the rest of the room. I was wondering if i could fill the spot in with something to better insulate the area. Any ideas?
kevin07 is offline   Reply With Quote
Old 12-16-2011, 07:12 PM   #2
DIY staff
Rewards Points: 7,174
Are the floor joists cantilevered off the foundation? Are they open from the basement?
You may need to dig yourself an access under that ---Have you watched 'The Great Escape'?
Old 12-16-2011, 07:20 PM   #3
Rewards Points: 13,472
There was suppost to be R19 insualtion then plywood under it.
Never just fill it in or you just but the wood closer to where insects (termites) can get in.
Old 12-16-2011, 07:50 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
It looks like trouble just waiting to happen with the soil being almost in direct contact with the cantilever.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-16-2011, 08:50 PM   #5
retired union carpenter
Send a message via Yahoo to coupe
I'm just guessing here! but, is there no inspections required where ever this is built?
that needs a foundation. what held those bricks up when laying?
as always, just my thoughts.
good luck
coupe/Larry
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-16-2011, 09:09 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That doesn't look like real bricks to me. Maybe a "thin brick" application.
Sure looks phony. I'll bet the bricks are just glued on to the structure.
XXX
Old 12-16-2011, 10:06 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,510
They are fake....look at the corners.....real brick, the ends would alternate...
ddawg16 is online now   Reply With Quote
Old 12-16-2011, 10:20 PM   #8
joed's Avatar
Rewards Points: 12,464
The bricks are not real. Look at the corners. The brick does not continue through the corner. There is a seem all the way up.
The ones on the window sill might be real.
Old 12-17-2011, 05:40 AM   #9
DIY staff
Remove carpet----open subfloor with a saw---air seal the area----add insulation--replace sub floor--reset the carpet.
That area will always be cooler than the rest of the room,due to the windows----getting the floor insulated and sealed will help a lot.
