Old 08-19-2012, 01:49 PM   #1
How do I figure out how many studs for a wall?
I have a wall that is 24' long by 10' an then my other wall is 20' long how do I figure how many studs are needed and how much insulation? The walls will be 16"oc
oyates is offline   Reply With Quote
Old 08-19-2012, 01:58 PM   #2
Framing Contractor
Usually figuring one stud per foot will get you pretty close. Insulation generally comes by the sq ft. Length of wall times height. Don't forget that you will need plates for the wall as well.
sixeightten is online now   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
oyates (08-19-2012)
Old 08-19-2012, 03:30 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
You have the key numbers. Now if you do not know how to do basic math, find a third grader that can take the length and figure out how many inches, then take that number and divide by 16.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 08-19-2012, 03:51 PM   #4
Yeah that one foot rule is good, somehow somewhere I am sure if you have any left over you will find a use for them. Guaranteed.
COLDIRON is offline   Reply With Quote
Old 08-19-2012, 04:01 PM   #5
JOATMON
ddawg16's Avatar
I use a different method.....
Since I want to make sure that studs land on 16" OC.....I think of it terms of a sheet of OSB (or drywall)....each sheet takes 3 studs (plus the end stud).....so if I have a wall 20' long....that is 5 sheets of OSB for the shearwall....5 x 3 + 1....16 studs....plus 2 20 footers for the top plate.....
Don't forget that if you windows or doors....you will need you jack stud and trimmers.....
When I first started off doing DIY....I tried to get my counts exact....after awhile I realized I was making too many trips back to HD for "one more piece".....now I make sure I buy extra.....I can always return what I don't use.....which in most cases, I end up using it anyway.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 08-19-2012, 04:17 PM   #6
Framing Contractor
2x4's are never technically "left over" There is always a use for a couple of them. Not to mention, they are very inexpensive and have a great shelf life.
Old 08-19-2012, 04:23 PM   #7
^^^^+1
If its just stud wall you can go length in ft x .8 But you will have corners that will eat up a couple.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-19-2012, 07:57 PM   #8
Super Moderator
Add an extra 10--that is what I always do--with doors--wall ends and blocking you will use them and more--
Old 08-19-2012, 09:02 PM   #9
In a little over my head
Windows and doors really add to the stud count. Especially if you want particular sizes or need them in a particular place.
ratherbefishing is offline   Reply With Quote
Old 08-19-2012, 09:18 PM   #10
Good shelf life....!.? No offense, but it seems I spend an hour picking out studs at Home Depot....Then I end up using half of them through the weekend, and must leave town for business (a slow DIYer . )
When I come home 5 days later....its a warped mess. lol
I have found if you don't use 2x4s right away...they may twist. Of course mildly twisted and warped ones are still usable in many instances
D270 is offline   Reply With Quote
The Following User Says Thank You to D270 For This Useful Post:
mae-ling (09-26-2012)
Old 08-19-2012, 09:43 PM   #11
gregzoll's Avatar
I have had 2x4's laying up in the attic of our garage, and never had any twist on me. Matter of fact, I have lumber up there from nine years ago, and still as straight as it was, when I brought it home.
The Following User Says Thank You to gregzoll For This Useful Post:
hand drive (08-19-2012)
Old 08-19-2012, 10:38 PM   #12
First problem is you said home depot for studs lol
You let then suck up moisture then yes they will warp like mad.
Old 08-20-2012, 01:07 AM   #13
Moderator
Figure 1 per foot as said, on a house.
Individual walls, almost as easy; 24'wall= 1/2 length(12) plus 1/2 that # =(6) plus (1)starter stud = 19 studs.
20' = 10+5+1 = 16 studs
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 09-26-2012, 02:46 PM   #14
Wow you must be lucky.
Every contractor I have known will come right out and say if you don't nail it up, it will bow/twist.
Old 09-26-2012, 02:56 PM   #15
Not always... This all depends on how you store the 2x4s.
Pressure Treated ones will definitely bow.
oodssoo is offline   Reply With Quote
Repairing rotten wall studs on exterior wall croms Remodeling 10 12-28-2011 04:47 PM
TV wall mount in drywall/foam/block combo with no studs? hstraf Building & Construction 4 09-06-2011 05:41 AM
Help - rotten exterior wall support studs Charbl General Discussion 2 11-15-2010 07:27 AM
Finding wall studs jmfma General Discussion 8 01-03-2010 06:06 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
