-   -   How do I figure out how many studs for a wall? (http://www.diychatroom.com/f19/how-do-i-figure-out-how-many-studs-wall-154187/)
oyates 08-19-2012 01:49 PM
I have a wall that is 24' long by 10' an then my other wall is 20' long how do I figure how many studs are needed and how much insulation? The walls will be 16"oc
sixeightten 08-19-2012 01:58 PM
Usually figuring one stud per foot will get you pretty close. Insulation generally comes by the sq ft. Length of wall times height. Don't forget that you will need plates for the wall as well.
gregzoll 08-19-2012 03:30 PM
You have the key numbers. Now if you do not know how to do basic math, find a third grader that can take the length and figure out how many inches, then take that number and divide by 16.
COLDIRON 08-19-2012 03:51 PM
Yeah that one foot rule is good, somehow somewhere I am sure if you have any left over you will find a use for them. Guaranteed.
ddawg16 08-19-2012 04:01 PM
I use a different method.....
Since I want to make sure that studs land on 16" OC.....I think of it terms of a sheet of OSB (or drywall)....each sheet takes 3 studs (plus the end stud).....so if I have a wall 20' long....that is 5 sheets of OSB for the shearwall....5 x 3 + 1....16 studs....plus 2 20 footers for the top plate.....
Don't forget that if you windows or doors....you will need you jack stud and trimmers.....
When I first started off doing DIY....I tried to get my counts exact....after awhile I realized I was making too many trips back to HD for "one more piece".....now I make sure I buy extra.....I can always return what I don't use.....which in most cases, I end up using it anyway.
sixeightten 08-19-2012 04:17 PM
2x4's are never technically "left over" There is always a use for a couple of them. Not to mention, they are very inexpensive and have a great shelf life.
Hammer450R 08-19-2012 04:23 PM
^^^^+1
If its just stud wall you can go length in ft x .8 But you will have corners that will eat up a couple.
oh'mike 08-19-2012 07:57 PM
Add an extra 10--that is what I always do--with doors--wall ends and blocking you will use them and more--:)
ratherbefishing 08-19-2012 09:02 PM
Windows and doors really add to the stud count. Especially if you want particular sizes or need them in a particular place.
D270 08-19-2012 09:18 PM
Good shelf life....!.? No offense, but it seems I spend an hour picking out studs at Home Depot....Then I end up using half of them through the weekend, and must leave town for business (a slow DIYer :(. )
When I come home 5 days later....its a warped mess. lol
I have found if you don't use 2x4s right away...they may twist. Of course mildly twisted and warped ones are still usable in many instances :thumbup:
gregzoll 08-19-2012 09:43 PM
I have had 2x4's laying up in the attic of our garage, and never had any twist on me. Matter of fact, I have lumber up there from nine years ago, and still as straight as it was, when I brought it home.
Hammer450R 08-19-2012 10:38 PM
First problem is you said home depot for studs lol
You let then suck up moisture then yes they will warp like mad.
Gary in WA 08-20-2012 01:07 AM
Figure 1 per foot as said, on a house.
Individual walls, almost as easy; 24'wall= 1/2 length(12) plus 1/2 that # =(6) plus (1)starter stud = 19 studs.
20' = 10+5+1 = 16 studs
Gary
D270 09-26-2012 02:46 PM
Wow you must be lucky.
Every contractor I have known will come right out and say if you don't nail it up, it will bow/twist.
oodssoo 09-26-2012 02:56 PM
Not always... This all depends on how you store the 2x4s.
Pressure Treated ones will definitely bow.
